using System; using System.Text; using ESRI.ArcGIS.Geodatabase; using ESRI.ArcGIS.esriSystem; namespace EngineProj { class Program { [STAThread] static void Main(string[] args) { string gdbName = @"C:\Projects\test\lines.shp"; IWorkspace workspace = null; ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.EngineOrDesktop); IAoInitialize ao = new AoInitializeClass(); ao.Initialize(esriLicenseProductCode.esriLicenseProductCodeArcEditor); Type factoryType = Type.GetTypeFromProgID("esriDataSourcesFile.ShapefileWorkspaceFactory"); IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(factoryType); // This line fails with COMException: Exception from HRESULT: 0x80040228 workspace = workspaceFactory.OpenFromFile(gdbName, 0); } } }
using ESRI.ArcGIS.Geodatabase; using ESRI.ArcGIS.DataSourcesFile; IWorkspaceFactory workspaceFactory = new ShapefileWorkspaceFactoryClass(); IWorkspace workspace = workspaceFactory.OpenFromFile(string_ShapefileDirectory, 0); IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)workspace; IFeatureClass featureClass = featureWorkspace.OpenFeatureClass(string_ShapefileName);
The workspace for a shapefile is the directory that contains the files that make up the shapefile. The problem with the code that you posted is that you're passing in the path to the *.shp file, which is incorrect. The workspace for a file geodatabase is also a directory. The workspace for a personal geodatabase is the database file. So, make sure you're passing in the correct path for the type of workspace you're trying to open. A recent thread also suggested that there is a bug when binding using the EngineOrDesktop option. If you have Engine installed but not licensed then the binding will fail even if you have Desktop installed and properly licensed.
