work with intersection point of the lines
1945
01-22-2014 12:43 AM
DenEsenal
hi everybody,
I am new to ArcObjects and looking to get some ideas.
There are several polyline and point features in GDB.
Need to add point to an existing point feature class. Point formed at the intersection of the lines
How to do this in the process of drawing a polyline?
Thanks in Advance.
WeifengHe
Occasional Contributor II
So you have your feature class, say featCls
IFeature feat = featCls.CreateFeature
feat.Shape = point //point is the intersection of the pplyline
feat.Store()
That's it, you just added the point to your feature class.
swapnabhide
Hi Den,
I am not aware how to add the intersection point while drawing polyline. However, below is the link for sample code to create point where polyline intersect. It is a VBA code You may need to modify the code as per your requirements.
http://help.arcgis.com/en/sdk/10.0/vba_desktop/conceptualhelp/index.html#//00010000002m000000
Hope this will be helpful to start with your requirement.
Regards,
Swapna.
DenEsenal
Hi Den,
Regards,
Swapna.
Hi Swapna!
Thanks/ VBA code works. Now I can find intersection points.:) �?ne step closer to my goal.
And my next problem is adding this points to existing point FC
WeifengHe
feat.Store()
DenEsenal
feat.Store()
Thanks Weifeng!
found an article about it
Updating features
