Can anyone help me?I have some code conversion problem....here's the code....
Private Sub Combo2_CLICK()
Label10.Caption = "C" & _
(Combo2.ItemData(Combo2.ListIndex) / 100)
End Sub
Private Sub Combo3_click()
Label13.Caption = "K" & _
(Combo3.ItemData(Combo3.ListIndex) / 100)
End Sub
Private Sub Form_Load()
Combo1.AddItem "a"
Combo1.ItemData(Combo1.NewIndex) = 99
Combo1.AddItem "b"
Combo1.ItemData(Combo1.NewIndex) = 71
Combo1.AddItem "c"
Combo1.ItemData(Combo1.NewIndex) = 65
End Sub
Private Sub Combo1_click()
Select Case Combo1.ListIndex
Case 0
Combo2.Clear
Combo2.AddItem "cc"
Combo2.ItemData(Combo2.NewIndex) = 99
Combo2.AddItem "dd"
Combo2.ItemData(Combo2.NewIndex) = 97
Combo2.AddItem "bb"
Case 1
Combo2.Clear
Combo2.AddItem "cc"
Combo2.ItemData(Combo2.NewIndex) = 71
Combo2.AddItem "bb"
Combo2.ItemData(Combo2.NewIndex) = 84
Combo2.AddItem "dd"
Combo2.ItemData(Combo2.NewIndex) = 88
Case 2
Combo2.Clear
Combo2.AddItem "cc"
Combo2.ItemData(Combo2.NewIndex) = 65
Combo2.AddItem "bb"
Combo2.ItemData(Combo2.NewIndex) = 48
Combo2.AddItem "dd"
Combo2.ItemData(Combo2.NewIndex) = 51
End Select
Case 1
Combo3.Clear
Combo3.AddItem "dd"
Combo3.ItemData(Combo3.NewIndex) = 70
Combo3.AddItem "gg"
Combo3.ItemData(Combo3.NewIndex) = 66
Case 2
Combo3.Clear
Combo3.AddItem "gg"
Combo3.ItemData(Combo3.NewIndex) = 74
End Select
End Sub
Private Sub Command3_Click()
Dim Qt As Single
Dim a As Single
Dim c As String
i = Text9.Text
a = Text10.Text
If Text15.Text = "" Then
c = Text15.Text
Else
c = Combo2.ItemData(Combo2.ListIndex) / 100
End If
Qt = Val(c) * i * a
Text13.Text = Qt
Exit Sub
errorhandler:
MsgBox "Please Check Your Data!"
End Sub
Private Sub Command2_Click()
On Error GoTo errorhandler
Dim Rn As Long
Dim u As Long
Dim es As Long
Dim ea As Long
Dim K As Long
Dim Ht As Long
Dim ET0 As Single
Rn = Text5.Text
u = Text3.Text
es = Text4.Text
ea = Text6.Text
K = Text7.Text
Ht = Text8.Text
Delta = (4098 * (0.618 * Exp((17.27 * Ht) / (Ht + 237.3)))) / (Ht + 237.3) ^ 2
Gamma = (0.001013 * ea) / (0.622 * 2.45)
ET0 = (0.408 * Delta * Rn + Gamma * (900 / (Ht + 273)) * u * (es - ea)) / (Delta + Gamma * (1 + 0.34 * u))
Text12.Text = ET0
Exit Sub
errorhandler:
End Sub
Private Sub Command1_Click()
i = Text1.Text
i2 = Text2.Text
Dim T As Integer
Dim Tmax As Integer
Dim Smax As Single
Dim s As Integer
Dim det As Single
Dim st As Integer
Dim Qt As Single
Dim st1 As Single
Dim R1 As Single
Dim R As Integer
R1 = Text14.Text
Smax = 1
st = Smax
T = 1
det = Text12.Text
Qt = Text13.Text
Do Until R > R1
Do Until T > Tmax
If i >= i2 Then
If st >= det Then
dt = det
Else
dt = st
End If
Else
dt = 0
End If
st1 = Qt + st - dt
Label1.Caption = st1
If st1 >= Smax Then
st1 = Smax
Else
st1 = st1
End If
If Qt >= det Then
Qtc = Qtc + 1
Else
Qtcf = Qtcf + 1
End If
If i >= i2 Then
ic = ic + 1
Else
icf = icf + 1
End If
If st1 >= det Then
st1c = st1c + 1
Else
st1cf = st1cf + 1
End If
If Qt + st1 >= det + i2 Then
Qst1c = Qst1c + 1
Else
Qst1cf = Qstc1f + 1
End If
R = (Qtc + ic + st1c + Qst1c) / (Qtc + ic + st1c + Qst1c + Qtcf + icf + st1cf + Qst1cf)
T = T + 1
Label8.Caption = R
Loop
Exit Sub
Loop
Exit Sub
errorhandler:
End Sub
I try to do it myself but it's stock with combobox in the firstPrivate Sub ComboBox1_click()
Select Case ComboBox1.ListIndex
Case 0
ComboBox2.Clear
ComboBox2.AddItem "0"
ComboBox2.Value = 99
ComboBox2.AddItem "10"
ComboBox2.Value = 97
ComboBox2.AddItem "20"
Case 1
ComboBox2.Clear
ComboBox2.Value = 71
ComboBox2.Value = 84
ComboBox2.Value = 88
Case 2
ComboBox2.Clear
ComboBox2.Value = 65
ComboBox2.Value = 48
ComboBox2.Value = 51
End Select
Case 1
ComboBox3.Clear
ComboBox3.AddItem "cc"
ComboBox3.Value = 70
ComboBox3.AddItem "dd"
ComboBox3.Value = 66
Case 2
ComboBox3.Clear
ComboBox3.Value = 74
End Select
End Sub
Private Sub ComboBox2_CLICK()
Label1.Caption = "C" & (ComboBox2.Value) / 100
End Sub
Private Sub ComboBox3_click()
Label2.Caption = "K" & (ComboBox3.Value) / 100
End Sub
Private Sub UserForm_Initialize()
ComboBox1.AddItem "0"
ComboBox1.Value = 99
ComboBox1.AddItem "10"
ComboBox1.Value = 71
ComboBox1.AddItem "20???"
ComboBox1.Value = 65
ComboBox1.Style = fmStyleDropDownList
End Sub
when I change first combobox and the following combobox will show 99 in ComboBox2.Value = 99and following calculate wil present 0 no matter which I changecan anyone help me to convert?Or anyone can give me a list about different with vb6.0 & vba? plz.....
