VB.Net code works differently between 9.3 Oracle and 10.2.2 SQL Server
816
06-02-2017 12:06 PM
AmyRose1
We have a tool that has a task to look at an existing feature class to find the highest number in a field called INDEX and return the next number. It then adds the next numbers to features that will be loaded into the main feature class.
When the tool is used and the data source is a 9.3 Oracle SDE point feature class it works correctly by returning the next highest number, but when I tried using it on a 10.2.2 SQL Server point feature class, it returns the next "available" number. In this case a feature had been deleted freeing up a number that was not the highest.  It was this number that the tool returned for the SQL Server feature class.
Here is the code for the function:
Any ideas why it is doing this?  Is there a difference in how the code behaves between the two versions?
I am going to create a point feature class that has no number gap and see if it works to confirm the possible issue.
Any thoughts appreciated,
Amy Rose
    Public Function GetNextHighestINDEX() As Long
        Try
            Dim pDS As IDataset
            Dim pTable As ITable
            Dim pCursor As ICursor
            Dim pRow As IRow
            Dim pQueryFilter As IQueryFilter
            Dim i As Long
            Dim pMxDoc As IMxDocument
            Dim pMap As IMap
            Dim pFLayer As IFeatureLayer
            Dim pFCls As IFeatureClass
            pMxDoc = My.ArcMap.Document
            pMap = pMxDoc.ActiveView
            '--- Set the input Point feature class
            pFCName = "GIS.POINTS"
            For i = 0 To pMap.LayerCount - 1
                If TypeOf pMap.Layer(i) Is IFeatureLayer Then
                    pFLayer = pMap.Layer(i)
                    pFCls = pFLayer.FeatureClass
                    pDS = pFCls
                    If UCase(pDS.Name) = UCase(Trim(pFCName)) Then
                        NodesFC = pFCls
                        Exit For
                    End If
                End If
            Next i
            If NodesFC Is Nothing Then
                MsgBox("No GIS.POINTS Layer Found in Map")
                Exit Function
            End If
            pTable = NodesFC
            pQueryFilter = New QueryFilter
            pQueryFilter.WhereClause = "INDEX is not null and (INDEX Like '1_____'  or INDEX Like '2_____' or INDEX Like '3_____'  or INDEX Like '4_____' or INDEX Like '5_____'  or INDEX Like '6_____' or INDEX Like '7_____'  or INDEX Like '8_____' or INDEX Like '9_____'  or INDEX Like '10_____')"
            Dim pTableSort As ITableSort = New TableSortClass()
            'pTableSort.Table = Table
            With pTableSort
                .Fields = "INDEX"
                .Ascending("INDEX") = False 'False for descending order
                .QueryFilter = pQueryFilter
                .Table = pTable
            End With
            'apply sort
            pTableSort.Sort(Nothing)
            'Use cursor to find highest number
            pCursor = pTableSort.Rows
            'There's no need to loop cause you just want the highest number so the first row should be it
            'Dim pRow As IRow
            pRow = pCursor.NextRow
            GetNextHighestINDEX = pRow.Value(NodesFC.Fields.FindField("INDEX")) + 1
        Catch ex As Exception
            MsgBox(ex.Message & ex.StackTrace)
        End Try
    End Function
AmyRose1
Well,
What a difference a weekend makes.  What worked on Friday is no longer working (I re-set a data source of a layer to see if it would work on the SQL Server point feature class that had the same name as the Oracle feature class).
My initial thought was that it would not work because the data owner was not the same between the databases.  So, it actually makes more sense now!
I will need to change the hard-coded name value from GIS.POINTS to SDE.POINTS.  If I have time and can figure it out, I would prefer having a "settings" dialog that allows for changing the feature classes via the GUI and NOT hard coded...
Hope the code snippet might help someone....
Amy Rose
NagmaYasmin
Hi Amy,
Please post your question in ArcObjects forum, thnaks.
https://community.esri.com/community/developers/gis-developers/arcobjects-sdk
Nagma
AmyRose1
Well,
Amy Rose
