UnitTesting and ArcObjects 10
3491
14
08-31-2011 01:34 AM
YvoWeidmann
Dear List
I am trying to use UnitTests with the provided framework within VisualStudio 2010 and ArcGIS (ArcEditor) with C#.
The main problem seems the initializing of the ArcObjects. As soon as I am using an ArcObject object in a test method the following exception is thrown:
System.Runtime.InteropServices.InvalidComObjectException: COM object that has been separated from its underlying RCW cannot be used.
As first I initialize the ArcObjects environment with a test method defined as [AssemblyInitialize]:
private static AoInitialize aoInitialize;
public static void AssemblyInitialize(TestContext context) {
RuntimeManager.BindLicense(ProductCode.EngineOrDesktop);
aoInitialize = new AoInitializeClass();
aoInitialize.Initialize(esriLicenseProductCode.esriLicenseProductCodeArcEditor);
The license is correctly checked out. But as mentioned, ArcObjects-based objects are throwing the InvalidComObjectException.
I tried several ways of initializing, but till now unsuccessfully.
Does anyone has an idea? I am looking for any hint.
Best regards,
Yvo
JohnHauck
Occasional Contributor II
I've not done much in the way of tests and haven't looked at this one in particular but wanted to share some things that I have seen in the past related to this. I know with VS 2008 by default Unit Test projects were set to execute in MTA mode. All ArcObjects components are marked as single threaded apartment (STA). STAs are limited to one thread each. So you needed to change the mode to STA. Also setting the runtime configuration manager to x86 may have an impact if you are running on a 64 bit system. Prior to VS 2010 SP1 new test projects would always target .NET 4.0 even if 3.5 was set in the new project dialog. .NET 4.0 won't be officially supported by ESRI until the ArcGIS 10.1 release. I would suggest that you also install SP1 for VS 2010 so you can properly target .NET 3.5.
I hope this helps!
RichardWatson
I use ArcObjects inside integration tests I have written using Visual Studio 2010 SP1 using the built-in C# unit test framework.  What I do is to initialize ArcObjects as part of the test, i.e. I have not tried any assembly level initialization.
I don't have the code in front of me but I think that I did use an attribute to try and force STA.
Oh, and I am using 9.3.1 but I would not think that that would make a difference (other than having to bind to a version).
If you send me an email then I'll send you a code snippet when I get back to the office next Tuesday.  rwatson at telcoridia dot com.
MelitaKennedy
Esri Notable Contributor
If you email him, use telcordia, not telcoridia!
YvoWeidmann
Hi
That sounds very reasonble:
Thank you very much for the hint.
But I was looking for the "switch" to change to STA. Can you give me another hint, how to do it.
Thank you very much,
Yvo
JohnHauck
Here is a Microsoft article that talks about how to Run Unit Tests in MTA mode. You would just want to use STA instead.
RichardWatson
Configure Visual Studio to use MTA.  The tests are run on different threads and ArcObjects do not handle this well.
BKuiper
I'm having similar problems with 10.1 (final release) and unit testing of ArcObject code. The license retrieval and usage is causing problems. Anybody found a proper way to initialize the license and keep it active during the tests while running the geoprocessor and arcobjects tools in STA ? I tried different things but haven't found a solution so far. Any tips or tricks would be helpful.
MannusEtten
so after a while nobody has a solution?
Nobody got a reply from Esri. Inc?
I am struggling with the issue too...
AlexanderGray
I use VS2008 but I put the AO license and product initialization in the ClassInitialize method of the test class with the appropriate method decorator.  I have never done it in the Assembly initialize method.
