Trying to find tool GUID or name for the Topology Split Polygons command
281
07-18-2012 02:00 PM
Howdy All,
I'm trying to find the GUID or the command name (i.e. "esriEditorExt.ConstructCommand" ) for the topology Split Polygons command. The icon for the command is:
[ATTACH=CONFIG]16219[/ATTACH]
I'm trying to use this command inside an vb.net project that is a command added to an extension that I've created... Any Ideas??? I've looked through the arcmap commands listing, but i didn't see anything that might match.
Thanks in advance,
Kevin Orcutt
GIS Developer/Consultant
City of Cincinnati - Cincinnati Area GIS (CAGIS)
(513) 850-1335 (cell)
Kevin.Orcutt@cincinnati-oh.gov
www.cagis.org
Reply
Regular Contributor III
All of the GUIDs are in the system registry under HKEY_CLASSES_ROOT.  The id for esriEditorExt.ConstructCommand is:
{05A81952-2C61-4D60-92C6-9D2737666D5C}
Reply
If you're using 10.x you can also find the guid through categories.exe in the arc bin directory.
Esri Mx Commands
esriEditorExt.SplitPolygonsWithLinesCommand
{5FA17370-794E-4F23-9E80-C47040CFD915}
Reply
