I've got a tool that needs to operate on a selected set of features in a layer. It then needs to process a subset of the selected features based on a query filter. This is straightforward. For example:
IFeatureSelection pFSel = (IFeatureSelection)pFLayer;
ISelectionSet pSelectionSet = pFSel.SelectionSet;
IQueryFilter pQF = new QueryFilter();
pQF.WhereClause = "MATERIAL = 'PL';
IFeatureCursor pCursor;
pSelectionSet.Search(pQF, true, out pCursor);
And pCursor holds the result.
Now, what if the layer in question is a join layer.
If I want to select from the join layer using a field in the joined table I can use SearchDisplayFeatures on IGeoFeatureLayer, as in:
IGeoFeatureLayer pGeoFLayer = (IGeoFeatureLayer)pFLayer;
pCursor = pGeoFLayer.SearchDisplayFeatures(pQF, true);
Which works fine. But if I want to subset an existing selection set using a query filter that references a field in the join table... well, I'm stumped. Any suggestions would be much appreciated.
Ed
