Schematic diagram generation using ArcObjects
4635
7
09-03-2014 08:02 AM
KevinLECOCQ
New Contributor III
Hi, I would like to generate a schematic diagram using ArcObjects (Java) but I didn't find any sample or documentation on how to do it, even in the .NET samples.
I only found this sample:
Generating Standard Builder diagrams by code
but it dates from ArcObjects 9.2 and is for VB.
I can't find any equivalent in java to this kind of instantiation:
Set pSchStandardBuilder = CreateObject("esriSchematic.SchematicStandardBuilder")
Does anyone knows how to use the Schematics ArcObjects API?
Thanks.
RickAnderson
Occasional Contributor III
There is a snippet in the api documentation...but...the link is broken
No nice way to do this other than copy/paste...here you go:
<?xml version="1.0" encoding="utf-8"?>
<CodeSnippets xmlns="http://schemas.microsoft.com/VisualStudio/2005/CodeSnippet">
  <CodeSnippet Format="1.0.0">
    <Header>
      <Title>Generate A Diagram From A Map Selection</Title>
      <Description>Generate a diagram from features selected in a geographic map</Description>
      <Author>Esri</Author>
    </Header>
    <Snippet>
      <Code Language="VB"><![CDATA[
#Region"Generate A Diagram From A Map Selection"
' ArcGIS Snippet Title:
' Generate A Diagram From A Map Selection
' Long Description:
' Generate a diagram from features selected in a geographic map
' Add the following references to the project:
' ESRI.ArcGIS.Carto
' ESRI.ArcGIS.Schematic
' Intended ArcGIS Products for this snippet:
' ArcGIS Desktop (Standard, Advanced)
' ArcGIS Engine
' Applicable ArcGIS Product Versions:
' 10.0
' 10.1
' Required ArcGIS Extensions:
' ArcGIS Schematics
' Notes:
' This snippet is intended to be inserted at the base level of a Class.
' It is not intended to be nested within an existing Function or Sub.
''' <summary>
''' Generate a diagram from features selected in a geographic map
''' </summary>
''' <param name="pMap">Geographic map containing the input selected GIS features</param>
''' <param name="schemDiagClass">SchematicDiagramClass; that is, diagram template on which the generated diagram is based</param>
''' <param name="schemDiagramContainer">SchematicDiagramContainer where the generated diagram will be stored</param>
''' <param name="DiagramName">Name for the generated diagram</param>
''' <returns>The generated ESRI.ArcGIS.Schematic.ISchematicDiagram</returns>
Public Function GenerateDiagramFromMap(ByVal pMap As ESRI.ArcGIS.Carto.IMap, ByVal schemDiagClass As ESRI.ArcGIS.Schematic.ISchematicDiagramClass, ByVal schemDiagramContainer As ESRI.ArcGIS.Schematic.ISchematicDiagramContainer, ByVal DiagramName As String) As ESRI.ArcGIS.Schematic.ISchematicDiagram
  ' if DiagramName is empty exit
        If (DiagramName.Length = 0) Then Return Nothing
        ' cast SchematicDiagramClass into ISchematicBuilder
        Dim schBuilder As ESRI.ArcGIS.Schematic.ISchematicBuilder = TryCast(schemDiagClass, ESRI.ArcGIS.Schematic.ISchematicBuilder)
        ' create the ISchematicStandardBuilderContext
        Dim objectType As Type = Type.GetTypeFromProgID("esriSchematic.SchematicStandardBuilderContext")
        ' if objectType is nothing, the BuilderContext cannot be created, then exit
        If (objectType Is Nothing) Then Return Nothing
        Dim schBuilderCtxt As ESRI.ArcGIS.Schematic.ISchematicStandardBuilderContext
        schBuilderCtxt = TryCast(Activator.CreateInstance(objectType), ESRI.ArcGIS.Schematic.ISchematicStandardBuilderContext)
        ' get the selected features in the map
        Dim enumFeature As ESRI.ArcGIS.Geodatabase.IEnumFeature = TryCast(pMap.FeatureSelection, ESRI.ArcGIS.Geodatabase.IEnumFeature)
        ' initialize the ISchematicStandardBuilderContext with the selection set
        schBuilderCtxt.InitialObjects = New EnumSchematicObject(enumFeature)
        ' generate the schematic diagram
        Return schBuilder.GenerateDiagram(DiagramName, schemDiagramContainer, Nothing, TryCast(schBuilderCtxt, ESRI.ArcGIS.Schematic.ISchematicBuilderContext), Nothing)
End Function
Public Class EnumSchematicObject
        Implements ESRI.ArcGIS.Geodatabase.IEnumObject
        Private m_pIEnumFeature As ESRI.ArcGIS.Geodatabase.IEnumFeature
        Public Sub New(ByVal pEnumFeature As ESRI.ArcGIS.Geodatabase.IEnumFeature)
  m_pIEnumFeature = pEnumFeature
        End Sub
        Public Function [Next]() As ESRI.ArcGIS.Geodatabase.IObject Implements ESRI.ArcGIS.Geodatabase.IEnumObject.Next
  If (m_pIEnumFeature IsNot Nothing) Then
  Return TryCast(m_pIEnumFeature.Next(), ESRI.ArcGIS.Geodatabase.IObject)
  Else
  Return Nothing
  End If
        End Function
        Public Sub Reset() Implements ESRI.ArcGIS.Geodatabase.IEnumObject.Reset
  If (m_pIEnumFeature IsNot Nothing) Then m_pIEnumFeature.Reset()
        End Sub
End Class
#End Region]]></Code>
    </Snippet>
  </CodeSnippet>
  <ArcGISSnippet>
    <XMLFormat>9</XMLFormat>
    <SnippetVersion>1</SnippetVersion>
    <ParentGUID>1258e6f9-7d5f-4958-b398-2ac88ff5d2ae</ParentGUID>
    <Language>VB</Language>
    <GUID>356f3b73-8545-41d0-9db4-aa8f6ad79ee9</GUID>
    <Name>Generate A Diagram From A Map Selection</Name>
    <LongDescription>Generate a diagram from features selected in a geographic map</LongDescription>
    <Products>
      <Product ProductType="Standard">ArcGIS Desktop</Product>
      <Product ProductType="Advanced">ArcGIS Desktop</Product>
      <Product ProductType="Engine">ArcGIS Engine</Product>
    </Products>
    <Extensions>
      <Extension>ArcGIS Schematics</Extension>
    </Extensions>
    <ArcGISAuthor>Esri</ArcGISAuthor>
    <ProductVersions>
      <ProductVersion>10.0</ProductVersion>
      <ProductVersion>10.1</ProductVersion>
    </ProductVersions>
    <SnippetType>function-sub-method</SnippetType>
    <References>
      <Reference>ESRI.ArcGIS.Carto</Reference>
      <Reference>ESRI.ArcGIS.Schematic</Reference>
    </References>
    <InputParameters>
      <Input ParameterType="ByVal">ESRI.ArcGIS.Carto.IMap</Input>
      <Input ParameterType="ByVal">ESRI.ArcGIS.Schematic.ISchematicDiagramClass</Input>
      <Input ParameterType="ByVal">ESRI.ArcGIS.Schematic.ISchematicDiagramContainer</Input>
      <Input ParameterType="ByVal">String</Input>
      <Input ParameterType="ByVal">ESRI.ArcGIS.Geodatabase.IEnumFeature</Input>
    </InputParameters>
    <ReturnParameters>
      <Return ParameterType="ByVal">ESRI.ArcGIS.Schematic.ISchematicDiagram</Return>
      <Return ParameterType="ByVal">ESRI.ArcGIS.Geodatabase.IObject</Return>
    </ReturnParameters>
    <Members>
      <Member LinkToComponentHelp="True">ESRI.ArcGIS.Schematic.ISchematicDiagram</Member>
      <Member LinkToComponentHelp="True">ESRI.ArcGIS.Schematic.ISchematicBuilder</Member>
      <Member LinkToComponentHelp="True">ESRI.ArcGIS.Schematic.ISchematicStandardBuilderContext</Member>
      <Member LinkToComponentHelp="True">ESRI.ArcGIS.Schematic.ISchematicStandardBuilderContext.InitialObjects</Member>
      <Member LinkToComponentHelp="True">ESRI.ArcGIS.Schematic.ISchematicBuilder.GenerateDiagram</Member>
    </Members>
    <CodeBody><![CDATA[
  ''' <summary>
  ''' </summary>
  End Function
        End Sub
            Else
                Return Nothing
            End If
        End Function
        End Sub
    End Class]]></CodeBody>
  </ArcGISSnippet>
</CodeSnippets>
KevinLECOCQ
New Contributor III
Thanks for your reply.
I understand how this sample works, but I don't know how to rewrite this kind of instantiation in Java:
considering there isn't any SchematicStandardBuilderContext class in the ArcObjects class package.
Do you know what's the equivalent?
Anne-YvonneBlin
New Contributor III
It appears that you figured out a real problem in our ArcObjects Java AP . We have some classes missing.
No solution at that time to create SchematicStandardBuilder and SchematicStandardBuilderContext objects from scratch using Java code...
KevinLECOCQ
New Contributor III
Yes, I realize that too.
And it seems that there is not many developers using ArcObjects + Java + Schematics...
KevinLECOCQ
New Contributor III
As a temporary solution, I will use C# instead of Java, only for the schematic diagram generation.
YuanLiu
For people that still have the same problem, please refer to ISchematicStandardBuilderProxy(ISchematicStandardBuilderProxy (ArcObjects Java API) )
and ArcGIS development using the Java API (http://resources.arcgis.com/en/help/arcobjects-java/concepts/engine/index.html#//000100000608000000 )
Vara_PrasadM_S
Hi Team,
When I run the same code in a console application by checking out the Schematics Extension license, it is generating an empty diagram but working fine as an addin.
Could someone please help me with this. Do we need to add the Schematic extension to the console application?
Thanks & Regards,
Vara Prasad
