Polyline outGeometry = new Polyline(); IGeometryCollection geometryCollection = null; if(geometryCollection == null) { IGeometryBag geometryBag = new GeometryBag(); geometryCollection = (IGeometryCollection) geometryBag; geometryBag.setSpatialReferenceByRef(mySpatialRef)); } // union all your polylines for(int i=0; i<featureList.size(); i++) { geometryCollection.addGeometry(featureList.get(i).getShape(), null, null); } outGeometry.constructUnion((IEnumGeometry) geometryCollection); ((ITopologicalOperator) outGeometry).simplify(); ITopologicalOperator topo ; geometry = ((ITopologicalOperator)geometry).getBoundary(); topo = (ITopologicalOperator)geometry ; IGeometry intersects = topo.intersect((IGeometry) outGeometry, esriGeometryDimension.esriGeometry0Dimension); IPointCollection Pts = (IPointCollection)intersects; for (int j=0;j<Pts.getPointCount();j++){ tempIntersectPointList.addPoint(Pts.getPoint(j), null, null); } firstPointOnEdge = tempIntersectPointList.getPoint(0) secondPointOnEdge = tempIntersectPointList.getPoint(tempIntersectPointList.getPointCount() - 1),
Dim pOverlapGeometryCollection As ESRI.ArcGIS.Geometry.IGeometryCollection = pTopoOp.Intersect(pInGeometry, ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry0Dimension) If pOverlapGeometryCollection IsNot Nothing Then For j As Integer = 0 To pOverlapGeometryCollection.GeometryCount - 1 pOverlapGeometry = pOverlapGeometryCollection.Geometry(j) pOverlapFeature = pOverlapBuffer pOverlapFeature.Shape = pOverlapGeometry pOverlapFeature.Value(pOverlapFeature.Fields.FindField(Field1)) = pFeature.OID pOverlapFeature.Value(pOverlapFeature.Fields.FindField(Field2)) = pSelFeature.OID pOverlapFCursor.InsertFeature(pOverlapBuffer) Next End If
I seem to get the intersecting points fine, my only issue is I cant seem to identify the point on the polygon edge. Getting the first and last point on the intersect point collection is not always the point on the edge of the polygon. That's what I'm still tryingto figure out.
Another question if someone knows the answer is why do I get so many points when I only use the polygon boundary to intersect the polyline. Shouldn�??t it just be two?
Dim pLayer As ESRI.ArcGIS.Carto.ILayer2 Dim pLayer1 As ESRI.ArcGIS.Carto.ILayer2 Dim pFLayer As ESRI.ArcGIS.Carto.IFeatureLayer Dim pFClass As ESRI.ArcGIS.Geodatabase.IFeatureClass Dim pFCursor As ESRI.ArcGIS.Geodatabase.IFeatureCursor Dim pFeature As ESRI.ArcGIS.Geodatabase.IFeature Dim pPolygonGeometry As ESRI.ArcGIS.Geometry.IGeometry Dim pLineGeometry As ESRI.ArcGIS.Geometry.IGeometry Dim pTopoOp As ESRI.ArcGIS.Geometry.ITopologicalOperator Dim pOverlapGeometryCollection As ESRI.ArcGIS.Geometry.IGeometryCollection Dim pOverlapGeometry As ESRI.ArcGIS.Geometry.IGeometry Dim pRgbColor As New ESRI.ArcGIS.Display.RgbColor Using releaser As New ESRI.ArcGIS.ADF.ComReleaser releaser.ManageLifetime(pFCursor) pLayer = My.ArcMap.Document.FocusMap.Layer(0) pFLayer = New ESRI.ArcGIS.Carto.FeatureLayer pFLayer = pLayer pFClass = pFLayer.FeatureClass pFCursor = pFClass.Search(Nothing, False) pFeature = pFCursor.NextFeature pLineGeometry = pFeature.Shape pLayer1 = My.ArcMap.Document.FocusMap.Layer(1) pFLayer = New ESRI.ArcGIS.Carto.FeatureLayer pFLayer = pLayer1 pFClass = pFLayer.FeatureClass pFCursor = pFClass.Search(Nothing, False) pFeature = pFCursor.NextFeature pPolygonGeometry = pFeature.Shape pTopoOp = pPolygonGeometry pOverlapGeometryCollection = pTopoOp.Intersect(pLineGeometry, ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry0Dimension) MsgBox(pOverlapGeometryCollection.GeometryCount) pRgbColor.Red = 255 For j As Integer = 0 To pOverlapGeometryCollection.GeometryCount - 1 pOverlapGeometry = pOverlapGeometryCollection.Geometry(j) FlashGeometry(pOverlapGeometry, pRgbColor, My.ArcMap.Document.ActiveView.ScreenDisplay, 500) ' this is an ArcGIS snippet Next End Using
Dim pPolygon As ESRI.ArcGIS.Geometry.IPolygon4 = pPolygonGeometry Dim pGeoBag As ESRI.ArcGIS.Geometry.IGeometryBag = pPolygon.ExteriorRingBag Dim pGeoCollection As ESRI.ArcGIS.Geometry.IGeometryCollection = pGeoBag MsgBox(pGeoCollection.GeometryCount)
