nullreferenceexception error
566
06-08-2011 07:22 PM
Gregory_KevinMorales
New Contributor III
hi,
im trying to creat a custom toolbar with tools for arcmap.
i have a combobox in it and added some codes in the ComboBox1_SelectedIndexChange() to remove all layers.
here's the code added
private sub ComboBox1_SelectedIndexChange()
removeLayers()
end sub
sub removeLayers()
Dim pMxDoc as IMxDocument = DirectCast(m_Application.Document, IMxDocument)
Dim pMap as IMap = pMxDoc.FocusMap
pMap.ClearLayers()
pMxDoc.UpdateContents()
pMxDoc.ActiveView.Refresh()
end sub
but when I start debugging to test if the code is working I get the error
NullReferenceException was unhandled bu user code
Object reference not set to an instance of an object.
can someone help me with this...
i'm using VS2008 and arcgis 9.3
Reply
