Hello,
after loading a QueryDef FeatureClass per Code (with IFeatureWorkspace.CreateQueryDef and .OpenFeatureQuery) and open the Layer Properties and the Tab Symbology, there are no Symbols loaded in the Symbol Selector if i wont to change the Style of my used Symbol, even there are some Style References by default (ESRI). The solution at the moment is to open the Style References check any of the Style Refernce and click ok. After that there are the default Style References loaded. Does someone has the same expirience with loaded QueryDef FeatureClasses? Back in ArcGIS 9.3 everything worked fine. Now with ArcGIS 10 SP 1 i have this strange behavior. Is there a differnt way now with ArcGIS 10 to load just a part of a FeatureClass then using CreateQueryDef?
Thanks in advance.
Karin
