For a variety of operations we load geodatabase layer tables into .net datasets as datatables. We use the data providers from esri to make this connection. The connection is as follows:
projConn = New OleDb.OleDbConnection("Provider=ESRI.GeoDB.OleDB.1;Data Source=" & daPath & ";Extended Properties=workspacetype=esriDataSourcesGDB.FileGDBWorkspaceFactory.1;Geometry=WKB")
And then to fill the dataset:
layDAdbf = New OleDb.OleDbDataAdapter
layDAdbf.FillSchema(daDataset, SchemaType.Mapped, layername)
layDAdbf.Fill(daDataset, layername)
This has worked for many years in a variety of product usages. We are now trying to use this from a Windows Service. It works in a console app, a scheduled task but not in a windows service. It always fails on the fill statement. With a File Geodatabase the program just ends - no error reporting even with a try-catch. The Windows event viewer reports the following:
Faulting module name: ntdll.dll, version: 6.1.7600.16695, time stamp: 0x4cc7ab86
Exception code: 0xc0000005
There appears to be many possible causes for this exception. Does anyone have any comments or suggestions - have you run into this issue.
Any help is greatly appreciated.
