I use arcengine for java in linux operation.
The exception I got was "AutomationException: 0x80004005 - Unspecified error".
My product version is arcengine 9.3 java for linux.
error in
at com.esri.arcgis.geodatabase.Workspace.openFeatureClass(Unknown Source)
code
String workspacePath = arcGISHome + "/java/samples/data/usa";
String featureClassName = "states.shp";
File shapefileFile = new File(workspacePath, featureClassName);
if (!shapefileFile.exists()) {
System.out.println("Shapefile " + shapefileFile.getAbsolutePath() + " doesn't exist. Exiting.");
System.exit(-1);
System.out.println("Shapefile: " + shapefileFile.getAbsolutePath());
try {
AoInitialize aoInitializer = new AoInitialize();
aoInitializer.initialize(esriLicenseProductCode.esriLicenseProductCodeEngine);
ShapefileWorkspaceFactory shapefileWorkspaceFactory = new ShapefileWorkspaceFactory();
Workspace workspace = new Workspace(shapefileWorkspaceFactory.openFromFile(workspacePath, 0));
FeatureClass featureClass = new FeatureClass(workspace.openFeatureClass(featureClassName)); int numFeatures = featureClass.featureCount(null);
System.out.println("There are " + numFeatures + " features:");
for (int i = 0; i < numFeatures; i++){
IFeature feature = featureClass.getFeature(i);
IGeometry geometry = feature.getShapeCopy();
System.out.println("Feature " + i + ": ");
System.out.println(getStringFromShape(geometry));
if (i >= 9) {
break; // 10 is enough
aoInitializer.shutdown();
System.out.println("Sample finished.");
} catch (Exception e) {
e.printStackTrace();
why use workspace.openFeatureClass in some errors,the shapefile's path and name is correct .
Any solution or workaround this?
Thank you very much in advance
