JoinField in geoprocessor giving errors
117
08-22-2013 06:58 AM
New Contributor III
HI,
I am in Arc10.0 using VB.net. trying to use the GP tool JoinField as shown below, but it keeps giving "Runtime.InteropServices.COMException (0x80004005)" ERRORS. I have used other GP tools just fine. FYI, below I have also tried adding the tables as objects and without the .dbf extension with no luck.
  Public Function Test_GP2()
        ' Create geoprocessor. Overwrite true will replace existing output.
        Dim pJoin As ESRI.ArcGIS.DataManagementTools.JoinField
        Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult
        Try
            ' Execute the tool
            pJoin = New ESRI.ArcGIS.DataManagementTools.JoinField
            pJoin.in_data = "C:\_Debbie\GapTool\Results\2\3S_3\Output\3S_3\E_3S_3.dbf"
            pJoin.in_field = "VALUE"
            pJoin.join_table = "V:\Natural_Resources\LandCover2000\LV2000\LV2000.dbf"
            pJoin.join_field = "UNIQUE_ID"
           Result = RunTool(pJoin, Nothing)
        Catch ex As Exception
            MsgBox("ERROR: " & m_Current_Address & " - Export table - " & " " & ex.Message)
        Finally
            pJoin = Nothing
            Result = Nothing
        End Try
    End Function
Public Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult
        Dim GP As ESRI.ArcGIS.Geoprocessor.Geoprocessor = New ESRI.ArcGIS.Geoprocessor.Geoprocessor()
        Try
            Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult)
            If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then MsgBox("error") 'ReturnMessages()
            GP.ClearMessages()
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Run Geoprocessor")
        End Try
        Return Result
    End Function
thanks,
Reply
New Contributor III
thanks for all your input, I am doing all the binding necessary for Engine, it was just this GP tool I had trouble with. Anyway, I figured it out. I have to pass in an object, table, not the literal string for the table. so all good now.
Cheers
Reply
MVP Frequent Contributor
Are the fields of different type? Are you trying to join a string field to a numeric?
Reply
New Contributor III
interesting question, but they are both integers. I have used the exact same parameters in ArcToolBox to perform this task, so I know this should work. THis is in arcEngine, in case that matters.
Reply
I have yet to develop an engine application but I know one needs to initialize ArcObjects as the first thing you must do before calling any ArcObjects, have you done this? Look on the forums for IAoInitialize. Whilst searching I found references to Binding to RuntimeManager not sure if you need to do that to?
Reply
New Contributor III
Cheers
Reply
