My code is gonna below:private void EagleEye_Load(object sender, EventArgs e) {
toolbar.SetBuddyControl(map_main.Object);
toc.SetBuddyControl(map_main.Object);
#region Even on Main map
//Update extend map.
private void map_main_OnExtentUpdated(object sender, ESRI.ArcGIS.Controls.IMapControlEvents2_OnExtentUpdatedEvent e) {
IRgbColor rgb = new RgbColorClass(); //The color of the Outline.
rgb.Red = 255;
rgb.Green = 0;
rgb.Blue = 0;
rgb.Transparency = 255;
ISimpleLineSymbol outLine = new SimpleLineSymbolClass(); //The outline.
outLine.Color = rgb;
outLine.Width = 3; //The width of the outline.
rgb = new RgbColorClass(); //The fill color.
rgb.Red = 255;
rgb.Green = 0;
rgb.Blue = 0;
rgb.Transparency = 0;
ISimpleFillSymbol fill = new SimpleFillSymbolClass(); //The fill style.
fill.Outline = outLine;
fill.Color = rgb;
IRectangleElement rectangle = new RectangleElementClass(); //The selection element.
IElement rectangleElement = rectangle as IElement;
IFillShapeElement shape = rectangleElement as IFillShapeElement;
shape.Symbol = fill;
rectangleElement.Geometry = (IEnvelope)e.newEnvelope;
IGraphicsContainer mapContainer = map_eagle.Map as IGraphicsContainer;
mapContainer.DeleteAllElements(); //Delete elements in the hawkeye map.
mapContainer.AddElement((IElement)shape, 0);
IActiveView view = mapContainer as IActiveView;
view.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null);
//Replace map.
private void map_main_OnMapReplaced(object sender, ESRI.ArcGIS.Controls.IMapControlEvents2_OnMapReplacedEvent e) {
map_eagle.Map.AddLayer(this.GetOverviewLayer(map_main.Map));
map_eagle.Extent = map_main.FullExtent;
map_eagle.ActiveView.Refresh();
private void map_main_OnFullExtentUpdated(object sender, ESRI.ArcGIS.Controls.IMapControlEvents2_OnFullExtentUpdatedEvent e) {
map_eagle.Extent = map_main.FullExtent; //Change the hawkeye map extent as the main map.
map_eagle.Refresh();
#endregion
#region Even on Halkeye map.
private void map_eagle_OnMouseMove(object sender, ESRI.ArcGIS.Controls.IMapControlEvents2_OnMouseMoveEvent e) {
if(e.button == 1) {
IPoint p = new PointClass();
p.PutCoords(e.mapX, e.mapY);
map_main.CenterAt(p);
map_main.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null);
private void map_eagle_OnMouseDown(object sender, ESRI.ArcGIS.Controls.IMapControlEvents2_OnMouseDownEvent e) {
if(map_main.LayerCount > 0) { //Has layer.
if(e.button == 1) { //Left click.
else if(e.button == 2) { //Right click.
map_main.Extent = map_eagle.TrackRectangle();
else throw new ArgumentNullException("???????????!");
#endregion
/// <summary>
/// Get the maxnum extent layer.
/// </summary>
/// <param name="map">The map that contains the layers..</param>
/// <returns>the maxnum extent layer</returns>
private ILayer GetOverviewLayer(IMap map) {
if(map.LayerCount <= 0) throw new ArgumentNullException("None layer!");
ILayer maxLayer = map.get_Layer(0);
for(int i = 1; i < map.LayerCount; i++) {
if(map.get_Layer(i).AreaOfInterest.Width > maxLayer.AreaOfInterest.Width)
maxLayer = map.get_Layer(i);
return maxLayer;
It seems that I refresh so much or someting else,and I always want to search for improving the performance.Could you launch someting? Thanks very much.
