Is it possible to cancel an edit event such as onCreateFeature from an event listener?
640
07-06-2017 04:07 PM
HarlanMarshall
New Contributor III
I'm creating an ArcMap extension to listen for onCreateFeature events and set an attribute value on the new feature. I want the user to get an ok/cancel dialog that will either proceed to create the feature or cancel the feature creation based on the user response.
private void m_editEvents_OnCreateFeature(ESRI.ArcGIS.Geodatabase.IObject obj)
    IFeature pFeature = obj as IFeature;
    if (pFeature != null) // will never be null on create new feature
        // get the new feature's table name
        ITable tbl = pFeature.Table as ITable;
        IDataset dataset = tbl as IDataset;
        string sTblName = dataset.Name.Split('.')[2].ToLower();
        // Implement user OK or Cancel message box
        bool resp = GetOKCancelResponse("Creating New " + sTblName.ToUpper() + " Feature", "Do you want to create a new " + sTblName + " point?");
        if (resp == false)
            //Cancel the operation
        else
            // do important stuff
private bool GetOKCancelResponse(string caption, string message)
    bool rslt = false;
    var result = MessageBox.Show(message, caption,
                                    MessageBoxButtons.OKCancel,
                                    MessageBoxIcon.Question);
    // If the no button was pressed ...
    if (result == DialogResult.OK)
        rslt = true;
    return rslt;
JeffMatson
Occasional Contributor III
You can use IEditor.AbortOperation().
JeffMatson
HarlanMarshall
New Contributor III
Thank you Jeff! That worked.
