Intersect, Union are failing on 10.1
1085
02-27-2013 09:50 AM
GhassanKarwchan
I am migrating .NET code that was running against 9.3, to make it work for 10.1.
There is part of the code that is failing when migrate to 10.1 and was working on 9.3
The code was doing intersect twice.
The code is like this
The intersection method is wrapped into this method
public IGeometry GetOverlappedGeometry(IGeometry sourceGeometry, IGeometry targetGeometry)
            IGeometry overlappedGeometry = null;
            if (!IsNullOrEmptyGeometry(sourceGeometry) && !IsNullOrEmptyGeometry(targetGeometry) && IsGeometryIntersect(sourceGeometry, targetGeometry))
                IGeometry localSourceGeometry;
                IGeometry localTargetGeometry;
                if (sourceGeometry.GeometryType > targetGeometry.GeometryType)
                    localSourceGeometry = targetGeometry;
                    localTargetGeometry = sourceGeometry;
                else
                    localSourceGeometry = sourceGeometry;
                    localTargetGeometry = targetGeometry;
                ITopologicalOperator targetOperator = localTargetGeometry as ITopologicalOperator;
                if (targetOperator != null)
                    targetOperator.Simplify();
                    IGeometry intersectGeometry = targetOperator.Intersect(localSourceGeometry, localSourceGeometry.Dimension);
                    if (!IsNullOrEmptyGeometry(intersectGeometry))
                        overlappedGeometry = intersectGeometry;
            return overlappedGeometry;
So the code is calling this method twice
IGeometry overlapped1 = GetOverlappedGeometry(geom1, geom2);
-- where geom1 is PolylineClass, and geom2 is PolygonClass;
IGeometry overlappe2 = GetOverlappedGeometry(geom2, overlapped1);
-- where geom2 is PolylineClass
The code is failing on the second statement,
and more specifically when we are calling the intersect method
and giving this error
Error HRESULT E_FAIL has been returned from a call to a COM component.
System.Runtime.InteropServices.ExternalException {System.Runtime.InteropServices.COMException}
HResult = -2147467259
WeifengHe
Can you please add the data so I can try to repro the issue?
Also, I'd set targetOperator.IsKnownSimple = false before calling Simplify.  Here targetOperator is of ITopologicalOperator2.
