IGxDialog Unable to Open Shapefiles
85
03-18-2020 06:44 AM
MatsHardy
I have tried to use IGxDialog to open shapefiles by the codes below:
public static string getInputFile()
    string filename;
    IEnumGxObject enumGxObj;
    IGxObject gxObj;
    IGxObjectFilterCollection gxFilterColl;
    IGxDialog gxDialog;
    IGxObjectFilter gxObjFilter;
    filename = "";
    try
        gxDialog = new GxDialog();
        gxFilterColl = (IGxObjectFilterCollection)gxDialog;
        gxDialog.AllowMultiSelect = false;
        gxObjFilter = new GxFilterShapefiles();
        //gxDialog.ObjectFilter = gxObjFilter;
        gxFilterColl.AddFilter(gxObjFilter, true);
        if (gxDialog.DoModalOpen(0, out enumGxObj))
            gxObj = enumGxObj.Next();
            filename = gxObj.FullName;
            Logger.Debug("getInputFile filename = " + filename);
    catch (Exception ex)
        Logger.Debug("getInputFile error: " + ex.Message);
    return filename;
But when the GxDialog is opened, the shapefiles are not found.
But the shapefiles are found in ArcCatalog
Are there any problems on the codes? Thanks.
Reply
GintautasKmieliauskas
Hi Mats,
On ArcGIS 10.3 your code works fine. What is your version of ArcGIS?
Reply
MatsHardy
Thanks. My ArcMap and ArcObjects are both 10.7.
Reply
KenBuja
MVP Honored Contributor
Do you need to limit this to only shapefiles or can any featureclass get selected? What happens when you use the GxFilterFeatureClasses filter?
Reply
