IGXDialog substitute for Arc 10 Engine
432
08-23-2013 07:03 AM
DebbieAlger
New Contributor III
OK, I realize that I can't use this in Engine now because of Binding and exclusive locks on licenses. I can use the Windows dialog box for most of my work, altho this is messy for raster files. BUT I have to be able to access datasets in geodatabases, and this can't be done in windows. Is there anything I can use?????  This is a big deal breaker.
thanks,,
by Anonymous User
Not applicable
Debbie,
You should be able to add the ControlsAddDataCommand to an existing toolbar to get the engine add data dialog. See Adding data to the ArcGIS Engine controls
DebbieAlger
New Contributor III
that sounds very encouraging, but I don't know how to use this. Do you have any examples?
thanks,
DebbieAlger
New Contributor III
Sean,
after looking at this closer, I don't think it will help. I don't have a toolbar in my application. I have a "button" that the user uses to add data. it is not related at all to a map viewer.
