I'm trying to use a billboard symbol from style gallery in globecontrol using IFeatureLayer
but I have a problem, the symbol is showed like a rectangle and not show lik billboard
In attachments the image of my result
I can manage style gallery symbols using IFeatureLayer ? How I can do ?
thanks
This is my code:
Private m_objGlobeControl As AxGlobeControl
Private m_FeatureLayer As IFeatureLayer
Public Sub AddFeature(ByVal stDati() As st_DataTarget_3d)
Create_Layer()
AddingFeature(stDati)
m_objGlobeControl.GlobeDisplay.RefreshViewers()
End Sub
Private Sub Create_Layer()
Dim pFeatureClass As IFeatureClass
pFeatureClass = CreateFeatureClass(esriGeometryType.esriGeometryPoint)
Dim pFLy As IFeatureLayer
pFLy = New FeatureLayer
With pFLy
.FeatureClass = pFeatureClass
.Name = m_NameLayer
.Cached = True
.Selectable = True
End With
Dim pSymbol As ISymbol = LoadStyleSymbol()
Dim pColor As IColor = New RgbColor
pColor.RGB = RGB(0, 255, 0)
pColor.Transparency = 255
Dim markerSymbol As IMarkerSymbol = TryCast(pSymbol, IMarkerSymbol)
markerSymbol.Color = pColor
markerSymbol.Size = 15
Dim pRend As IFeatureRenderer
Dim pSimpleRend As ISimpleRenderer
Dim pGeoFL As IGeoFeatureLayer
If Not IsNothing(pSymbol) Then
pRend = New SimpleRenderer
pSimpleRend = pRend
pSimpleRend.Symbol = markerSymbol
pGeoFL = pFLy
pGeoFL.Renderer = pRend
End If
m_objGlobeControl.Globe.AddLayerType(pFLy, esriGlobeLayerType.esriGlobeLayerTypeDraped, True)
m_FeatureLayer = pFLy
End Sub
Private Sub AddingFeature(ByVal stDati() As st_DataTarget_3d)
Dim pFeatureClass As IFeatureClass = Nothing
Dim pFeature As IFeature = Nothing
Dim pPoint As IPoint
pFeatureClass = m_FeatureLayer.FeatureClass
pFeature = New Feature
For iConta As Integer = 0 To (stDati.Length - 1)
If Not IsDBNull(stDati(iConta).Latitudine) And Not IsDBNull(stDati(iConta).Longitudine) Then
pFeature = pFeatureClass.CreateFeature
pPoint = New Point
pPoint.PutCoords(stDati(iConta).Longitudine, stDati(iConta).Latitudine)
Dim za As IZAware = TryCast(pPoint, IZAware)
za.ZAware = True
pPoint.Z = 25
With pFeature
.Shape = pPoint
.Store()
End With
End If
End Sub
Private Function CreateFeatureClass(ByVal TipoGeometria As esriGeometryType) As IFeatureClass
Dim pFWS As IFeatureWorkspace = Nothing
Dim pWorkspaceFactory As IWorkspaceFactory
Dim pWorkSpaceName As IWorkspaceName
Dim pName As IName
Dim pFields As IFields
Dim pFieldsEdit As IFieldsEdit
Dim pField As IField
Dim pFieldEdit As IFieldEdit
Dim pGeomDef As IGeometryDef
Dim pGeomDefEdit As IGeometryDefEdit
Dim pFeatClass As IFeatureClass
pWorkspaceFactory = New FileGDBWorkspaceFactoryClass()
pFWS = pWorkspaceFactory.OpenFromFile(My.Application.Info.DirectoryPath & "\FGDB\NEMO-TMP-FGDB.gdb", 0)
Dim pEnumDS As IEnumDataset = TryCast(pFWS, IWorkspace).Datasets(esriDatasetType.esriDTFeatureClass)
Dim pDS As IDataset = pEnumDS.Next
Do Until pDS Is Nothing
If pDS.Name = m_NameLayer Then
pDS.Delete()
Exit Do
End If
pDS = pEnumDS.Next
Loop
pFields = New Fields
pFieldsEdit = pFields
pField = New Field
pFieldEdit = pField
pFieldEdit.Name_2 = "OID"
pFieldEdit.Type_2 = esriFieldType.esriFieldTypeOID
pFieldsEdit.AddField(pField)
pField = New Field
pFieldEdit = pField
pFieldEdit.Name_2 = "Shape"
pFieldEdit.Type_2 = esriFieldType.esriFieldTypeGeometry
pGeomDef = New GeometryDef
pGeomDefEdit = pGeomDef
With pGeomDefEdit
.GeometryType_2 = TipoGeometria
.SpatialReference_2 = TryCast(m_objGlobeControl.Globe, IBasicMap).SpatialReference
.HasZ_2 = True
End With
pFieldEdit.GeometryDef_2 = pGeomDef
pFeatClass = pFWS.CreateFeatureClass(m_NameLayer, pFields, Nothing, Nothing, esriFeatureType.esriFTSimple, "Shape", "")
CreateFeatureClass = pFeatClass
End Function
Private Function LoadStyleSymbol() As ISymbol
Dim styleGallery As IStyleGallery = New ServerStyleGalleryClass()
Dim styleStorage As IStyleGalleryStorage = TryCast(styleGallery, IStyleGalleryStorage)
styleStorage.TargetFile = "C:\Programmi\ArcGIS\Engine10.0\Styles\3D Billboards.ServerStyle"
styleStorage.AddFile("C:\Programmi\ArcGIS\Engine10.0\Styles\3D Billboards.ServerStyle")
Dim enumStyleGalleryItem As IEnumStyleGalleryItem = styleGallery.Items("Marker Symbols", "C:\Programmi\ArcGIS\Engine10.0\Styles\3D Billboards.ServerStyle", "")
enumStyleGalleryItem.Reset()
Dim styleItem As IStyleGalleryItem = enumStyleGalleryItem.Next()
While (styleItem IsNot Nothing)
If styleItem.Name = "Red Pushpin 3" Then
Exit While
End If
styleItem = enumStyleGalleryItem.Next()
End While
Dim pSymbol As ISymbol = TryCast(styleItem.Item, ISymbol)
Return pSymbol
End Function
