I have written an application that gives users access to many functions, some of which employ ArcGIS functionality (like processing rasters etc). I am able to 'bind' to an ArcGIS instance and license just fine with:
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.EngineOrDesktop)
Dim pAoInitialize As AoInitialize
Dim licenseStatus As esriLicenseStatus
Dim productCode As esriLicenseProductCode
'Create an AOInitialize object
pAoInitialize = New AoInitialize
Select Case UCase(Ltype)
Case "ARCINFO"
productCode = esriLicenseProductCode.esriLicenseProductCodeArcInfo
Case "ARCEDITOR"
productCode = esriLicenseProductCode.esriLicenseProductCodeArcEditor
Case "ARCVIEW"
productCode = esriLicenseProductCode.esriLicenseProductCodeArcView
Case Else
End Select
licenseStatus = pAoInitialize.Initialize(productCode)
Question is, how do I then 'close' or 'unbind' from the license without closing the application? Our users access licenses from a pool and are charged on a usage rate, so being able to disconnect when not using the license would be great. We can do with extensions using checkin/checkout, however 'shutdown' is not working for me. The license is still allocated, only becoming available in the pool when the application is closed.
I'm using ArcGIS 10, VB .NET.
Rob
