How to symbolize a Layer with a layerfile stored in an Add-In
3299
03-20-2015 01:55 PM
WilliamKirchhoff
Here's the answer to a question I never got around to asking three days ago (no, I'm not looking for points - I just hope it saves someone else hours of fruitless searching).
I am writing an Add-In that creates featureclasses that I want to add symbology to before they are added to ArcMap.  I created a template layer in an ArcMap session that provides the proper symbology then saved it out to a layerfile.  The idea is to deploy the layerfile along with the add-in.  A solution cobbled together from various sources (thanks to those who contributed, unfortunately I've lost the cites...)
1. In Visual Studio - create a new folder under your add-in project folder called (in this instance) "Layerfiles"
2. Copy / paste the template layerfile into the new folder
4. Set the saved layerfiles properties: Build Action = Content, Copy to Output Directory = Copy Always
3. Add method to project
        private void AddSavedLayerFileToMap(string folderName, string layerName, IFeatureClass gpsFClass, string aliasName)
            try
                //... Get map from current MxDocument
                IMap pMap = pMxDoc.ActiveView.FocusMap;
                //... Get the path to the layerfile
                string codeBase = Assembly.GetExecutingAssembly().CodeBase;
                UriBuilder uri = new UriBuilder(codeBase);
                string AsmPath = System.IO.Path.GetDirectoryName(Uri.UnescapeDataString(uri.Path));
                string layerFilePath = System.IO.Path.Combine(AsmPath, folderName + "\\" + layerName);
                //... Create the layer to add to ArcMap
                ILayerFile layerFile = new LayerFileClass();
                layerFile.New(layerFilePath);
                ILayer pSymbolLayer = layerFile.Layer;
                IFeatureLayer pSymFLayer = (IFeatureLayer)pSymbolLayer;
                pSymFLayer.FeatureClass = gpsFClass;
                pSymbolLayer.Name = aliasName;
                pMap.AddLayer(pSymFLayer);
            catch (Exception ex)
                MessageBox.Show(ex.Message);
The values of the parameters:
foldername - name you gave to the folder you added to your project folder in Visual Studio
layername - name of the template layerfile you added to the above folder
featureclass - the featureclass you want to add to ArcMap symbolized with the layerfile template
aliasName - a friendly name to call the layer once its added to the TOC in ArcMap
Reply
