Hi Hornbydd and TomLUX: Thank you for your suggestion. After some study I found that in our corresponding manual data process step, the "Locate Feature Along Routes" Linear Referencing Tool is used to generate an output event table. I decide to use the IRouteLocatorOperations interface to find the M-value of the point. I understand I will need to create temporary layer if I use this method. Thank you.
