How to get the coordinate of a polygon in arcgis engine?
2422
12-09-2013 07:20 AM
kju
New Contributor III
suppose that the shape of the polygon is rectangle,how can I get all the corner coordinates,for example,how to get them by programing in arcgis engine?Thanks very much. [ATTACH=CONFIG]29681[/ATTACH]
when switch the polygon to the "editor" status in arcmap,we can see each of the point,
[ATTACH=CONFIG]29682[/ATTACH]
so how to get them in arcgis engine programing? thanks...
NeilClemmons
Regular Contributor III
All polygon geometries implement IPointCollection which can be used to get each vertex of the geometry.  If the geometry is a true rectangle it will implement IEnvelope which has properties each of the points.
