How to get subtypes from tables in arcobjects
1737
09-10-2019 08:38 AM
Ruben_DarioCalero_Clavijo
New Contributor II
Hello
Everyone
I have a problem to get the subtypes from tables in arcmap with the arcobjects library in C# (sharp) lenguage.
So i need that someone could help me with some code example.
Appreciating the attention
DuncanHornby
MVP Notable Contributor
Have a look at this page on the API help file, whilst it's about creating subtypes you should be able to figure out how to access existing subtypes.
WeifengHe
public void GetSubtypes(IFeatureClass featureClass) {     // Cast the feature class to the ISubtypes interface.    ISubtypes subtypes = (ISubtypes)featureClass;      // then you can enumeraate subtypes.    IEnumSubtype enumSubtype = subtypes.Subtypes
KunalSeth
New Contributor II
You Can Use the Following Code (C#) -
//here item is a IfeatureClass
ISubtypes subtypes = item as ISubtypes;
if (subtypes.HasSubtype)
IEnumSubtype enumSubtype = subtypes.Subtypes;
enumSubtype.Reset();
int subcode = -1;
string subdesc = enumSubtype.Next(out subcode);
while (!string.IsNullOrEmpty(subdesc))
//str3 is a string (empty)
str3 = subdesc;
//in this above code you can able to find subtype names associated with each featurelayer
