How to get features not getting intersected in arcobjects
5957
10
05-01-2015 06:03 AM
akshayloya
Occasional Contributor II
Hi all,
I have two feature classes. I'm intersecting both of them. I have to return features which does not intersect with the other.
Lets take an example.
I have two feature classes: villages and colleges. I'm intersecting both of them.
My query is "Select villages having population greater then 500 not having colleges."
So villages having population greater then is working finely but then it spatially search for colleges in those villages.
what all I need is to select villages which does not have colleges.
Any help would be appreciable. Thanx in advance
Regards
JavierArtero
New Contributor III
Hi again Akshay,
When you call FillCache method in ISpatialCacheManager, you must specify the extent of the cache as a parameter.
You can pass any extent you want.
It could be the visible extent, which can be obtained via IActiveView.Extent at ArcObjects Help for .NET developers.
Or could be the map's area of interest (IMap.AreaOfInterest at ArcObjects Help for .NET developers)
Or whichever IEnvelope you create.
Hope this will be of help. Good luck.
JoshuaBixby
MVP Esteemed Contributor
This can be accomplished in two steps using Select By Attribute and Select By Location in ArcMap.  First, select all villages having greater than 500.  Then, "remove from currently selected features..." the villages that have colleges in them.
If scripting, something like:
arcpy.SelectLayerByAttribute_management("villages","NEW_SELECTION", "population > 500")
arcpy.SelectLayerByLocation_management("villages", "INTERSECT", "colleges", "", "REMOVE_FROM_SELECTION")
akshayloya
Hi Joshua,
I needed solution for arcobjects.
Thanx for the reply though.
Regards
OwenEarley
Occasional Contributor III
You can use the same tools in ArcObjects using the Geoprocessor managed assembly - for example:
            using ESRI.ArcGIS.Geoprocessor;
            using ESRI.ArcGIS.DataManagementTools;
            gp = new Geoprocessor();
            var tool = new SelectLayerByAttribute();
            tool.in_layer_or_view = "villages";
            tool.selection_type = "NEW_SELECTION";
            tool.where_clause = "population > 500";
            gp.Execute(tool, null);
JoshuaBixby
Ah, right, my bad.  One of my streams aggregated your post, and I didn't pay close enough attention that you were focused on ArcObjects.  As Javier Artero​ points out, a disjoint mask as he provides should get you on the right path.
JavierArtero
New Contributor III
If you are using the SpatialFilter object via the ISpatialFilter interface, you will need to define your own SpatialRelDescription, since the SpatialRel enumeration doesn't have the relationship you need.
You can query the features that doesn't intersect the query geometry setting the SpatialRel property to esriSpatialRelRelation
and SpatialRelDescription property to "FF*FF****"
More information at: SpatialRelDescription on ArcObjects 10 .NET SDK Help
akshayloya
Thanks Javier.
akshayloya
Any Idea How can I improve performance of my spatial query?
JavierArtero
New Contributor III
You could try using a spatial cache. This should take the data from the geodatabase and put it in memory, thus having a faster access since the queries won't be doing roundtrips to the file system.
Take a look at: ISpatialCacheManager at ArcObjects Help for .NET developers
akshayloya
Hi Javier,
I'm new to arcobjects.
May be a silly question but can you please tell me how to set the Cache extent. Like they have used in the link which you have provided.
