pInPoint = New Point ' Create a new point pInPoint.SpatialReference = pSpatialRef ' Previously obtained Spatial Reference from input lines pInPoint = pSegment.ToPoint ' Set the new point to the point of interest from the segment pInPoint.M = distAlong ' in other parts of my code distAlong keeps track of accumulated 3D distances along the line pSegment.ToPoint = pInPoint ' replace the point of interest with the modified M coordinate
SegCount = pSegColl.SegmentCount For j = 0 To SegCount - 1 pSegment = pSegColl.Segment(j) pInPoint = New Point 'If you needed to modify the segment points do the next steps pInPoint.SpatialReference = pSpatialRef pInPoint = pSegment.FromPoint ' Do something with the segment point pSegment.FromPoint = pInPoint pSegColl.SegmentsChanged() ' Send out Segment Changed Message event pInPoint = Nothing ' Clean up Point Object Next j
Take a look at the IHitTest interface. It can tell you if a point is on the line as well as the segment index of the segment in the line's segment collection. If the line is multi-part, it will also tell you the part index in the line's geometry collection.
