How to extract symbol properties using VBA?
1988
01-24-2012 03:44 AM
ChristineGo
I am writing a VBA program to extract symbol properties under feature layers of a MxDocument.
I'm able to extract properties like symbol colors and line width, but when I try to get more detail,
I'm not able to tell whether a symbol is SimpleLineSymbol or MarkerLineSymbol.
My program is like this:
Dim pGFL As IGeoFeatureLayer
Dim pSbl As ISymbol
Dim pSPR As ISimplyRenderer
Dim pMLS As IMarkerLineSymbol
If TypeOf pGFL.Renderer Is ISimpleRenderer Then
    Set pSPR = pGFL.Renderer
    If pFL.FeatureClass.ShapeType = esriGeometryPolyline Then
        Set pMLS = pSbl
        MsgBox "Marker Symbol Size = " & pMLS.MarkerSymbol.Size
    End If
End If
But I got error when I came over Set pMLS = pSbl.
If I define pMLS as MarkerLineSymbol instead of IMarkerLineSymbol, the statement Set pMLS = pSbl works,
but then it'll say pMLS.MarkerSymbol is a undefined method.
If I declare pMLS as ILineSymbol, I can set pMLS = pSbl, but I'm not able to get the MarkerSymbol related properties.
Could anyone share with me:
(1) How to obtain the Marker Symbol related properties from a ISymbol?
(2) How to determine the type of Symbol, e.g., SimpleLineSymbol or MarkerLineSymbol?
Thanks.
NeilClemmons
Regular Contributor III
You do it the same way you're checking for the renderer type in your code, by using TypeOf.  The symbol for a polyline layer will be of type ILineSymbol.  There are several coclasses that implement ILineSymbol  - MarkerLineSymbol and SimpleLineSymbol are only two of them so you'll need to check for all of the others as well.
Dim lineSymbol As ILineSymbol = simpleRenderer.Symbol
If TypeOf lineSymbol Is IMarkerLineSymbol Then
  ' marker line symbol
ElseIf TypeOf lineSymbol Is ISimpleLineSymbol Then
  ' simple line symbol
End If
ChristineGo
I did something like this, but why it didn't work?
The program error out in the 'Set' statement.
Dim Symbol As ISymbol = simpleRenderer.Symbol
Dim MLSymbol As IMarkerLineSymbol
Dim SLSymbol As ISimpleLineSymbol
If TypeOf Symbol Is IMarkerLineSymbol Then
  Set MLSymbol = Symbol
ElseIf TypeOf Symbol Is ISimpleLineSymbol Then
  Set SLSymbol = Symbol
End If
ChristineGo
What's the difference between interface and co-class?
When we use 'TypeOf', should we use 'TypeOf xxx Is' followed by an interface or followed by a co-class?
I ask this because when I check a linesymbol against the interface of different linesymbols, I got no match;
when I use co-class, I got all match.
NeilClemmons
You use the interface when checking types with TypeOf.  Keep in mind that a symbol can be many different types.  If you look at the help for ISymbol then you'll see a list of all the coclasses that implement that interface.  In theory, it could be any of them but you can rule some of them out simply because it's a symbol being used by a line layer.  That's why I suggested only testing for the ILineSymbol types.  If you look at the help for ILineSymbol then you'll see the list of coclasses that you should be checking for.
