ISegmentCollection segmentCollection = new PolygonClass(); segmentCollection.SetCircle(point, 10); IGeometry circle = segmentCollection as IGeometry;
you have some options:ISegmentCollection segmentCollection = new PolygonClass(); segmentCollection.SetCircle(point, 10); IGeometry circle = segmentCollection as IGeometry;
or you can cast the point to ITopologicalOperator and use buffer
or you can rotate a vector from a center point
or use EllipticArcClass
and so on..
