How to display symbol frol ServerStyle
612
7
03-14-2012 03:27 AM
FabrizioPuddu
hi,
I try to display the symbol, example 3D Billboards.ServerStyle, on arcglobe control. I get ISymbol from gallery and add a GraphicsLayer, but the symbol is not display fine, it's under the data surface.
this is my code:
Dim globeGraphicsLayer As ESRI.ArcGIS.Carto.IGraphicsContainer = New ESRI.ArcGIS.GlobeCore.GlobeGraphicsLayerClass
Dim layer As ESRI.ArcGIS.Carto.ILayer = CType(globeGraphicsLayer, ESRI.ArcGIS.Carto.ILayer) 'Explicit Cast
layer.Name = "PIPPO"
Dim scene As ESRI.ArcGIS.Analyst3D.IScene = CType(Me.m_objGlobeControl.Globe, ESRI.ArcGIS.Analyst3D.IScene) ' Explicit Cast
scene.AddLayer(layer, True)
Dim styleGallery As IStyleGallery = New ServerStyleGalleryClass()
Dim styleStorage As IStyleGalleryStorage = TryCast(styleGallery, IStyleGalleryStorage)
styleStorage.TargetFile = "C:\Programmi\ArcGIS\Engine10.0\Styles\3D Billboards.ServerStyle"
styleStorage.AddFile("C:\Programmi\ArcGIS\Engine10.0\Styles\3D Billboards.ServerStyle")
Dim enumStyleGalleryItem As IEnumStyleGalleryItem = styleGallery.Items("Marker Symbols", "C:\Programmi\ArcGIS\Engine10.0\Styles\3D Billboards.ServerStyle", "")
enumStyleGalleryItem.Reset()
Dim styleItem As IStyleGalleryItem = enumStyleGalleryItem.Next()
While (styleItem IsNot Nothing)
    If styleItem.Name = "Red Pushpin 3" Then
         Exit While
    End If
    styleItem = enumStyleGalleryItem.Next()
End While
Dim pSymbol As ISymbol = New SimpleMarkerSymbolClass()
pSymbol = TryCast(styleItem.Item, ISymbol)
Dim pColor As IColor = New RgbColor
pColor.RGB = RGB(0, 255, 0)
pColor.Transparency = 255
Dim point As ESRI.ArcGIS.Geometry.IPoint = New ESRI.ArcGIS.Geometry.PointClass
point.PutCoords(35.4802, 33.9008)
Dim pMarkerElement As IMarkerElement = New MarkerElementClass()
Dim markerSymbol As IMarkerSymbol = TryCast(pSymbol, IMarkerSymbol)
markerSymbol.Color = pColor
markerSymbol.Size = 200
Dim pElement As IElement = TryCast(pMarkerElement, IElement)
pElement.Geometry = point
pMarkerElement.Symbol = markerSymbol
Dim markerElement_2 As ESRI.ArcGIS.Carto.IMarkerElement = CType(pMarkerElement, ESRI.ArcGIS.Carto.IMarkerElement) ' Explicit Cast
markerElement_2.Symbol = markerSymbol
globeGraphicsLayer.AddElement(pMarkerElement, 1)
thanks
NeilClemmons
Regular Contributor III
You're not giving the point a z value so the element is being positioned at the coordinates you gave it but at elevation 0.  When you create the point, make it z aware and give it an appropriate value.
FabrizioPuddu
ahhh you are right Neil, I have correct my code but the symbol is on horizontal plane and not in 3d.
Are you sure that my code is correct ? because I suppose it should be used an 3d object (marker)
thanks for your effort
fabrizio
my code correct:
  Exit While
End If
End While
Dim za As IZAware = TryCast(point, IZAware)
za.ZAware = True
point.Z = 25
NeilClemmons
The problem may be here:
Don't set the symbol to a new instance of the SimpleMarkerSymbolClass.  Just do this:
Dim pSymbol As ISymbol = TryCast(styleItem.Item, ISymbol)
The symbol probably isn't a SimpleMarkerSymbol but a Marker3DSymbol.
FabrizioPuddu
in my previous post I forgot the attachment with the image, I change :
in:
but the result is the same
thanks
FabrizioPuddu
anyone can help me
thanks
NeilClemmons
There are probably other properties you need to set on the symbol.  It looks like the 3d marker symbol classes all implement IMarker3DPlacement so try setting the various properties on that interface and see if it does what you want.
FabrizioPuddu
thanks Neil you are very kind,
I solved it now.
I have to used and set IGlobeGraphicsElementProperties, but very important I have to used IGlobeGraphicsLayer
It works fine
        ' Create and add the graphics layer to ArcGlobe
        Dim globeGraphicsLayer As IGlobeGraphicsLayer = New ESRI.ArcGIS.GlobeCore.GlobeGraphicsLayerClass
        ' Add the graphics layer
                Exit While
            End If
        End While
        markerSymbol.Size = 25
        ' Set the geometry
        za.ZAware = True
        point.Z = 25
        Dim markerElement As ESRI.ArcGIS.Carto.IElement = New ESRI.ArcGIS.Carto.MarkerElementClass
        markerElement.Geometry = point
        Dim GlobeGraphicsProps As IGlobeGraphicsElementProperties = New GlobeGraphicsElementProperties
        GlobeGraphicsProps.FixedScreenSize = True
        GlobeGraphicsProps.Rasterize = False
        ' Add to the graphics layer
        Dim markerElement_2 As ESRI.ArcGIS.Carto.IMarkerElement = CType(markerElement, ESRI.ArcGIS.Carto.IMarkerElement) ' Explicit Cast
        globeGraphicsLayer.AddElement(markerElement, GlobeGraphicsProps, 1)
