There is a command in ArcMap->File->'Analyze Map...'. This analyzes the current map and shows if there are any errors or warnings. Like for example : 'Layer's data source has a different projection [Unknown] than the data frame's projection' and many more. Can I do this same operation through my C# code (ArcObjects) and identify the errors or warnings it shows ?
Any reply would be greatly appreciated.
Thanks ,
Sowmya.
