How to add new field to a feature class with VBA ArcObject
901
11-07-2011 07:17 AM
JonNewt
Can anyone show me how to add a new field to a feature class using VBA. Thank you very much in advance.
JeffreyHamblin
This will add an Integer type field named "Count" to the feature class of a selected feature layer. It is just the basics, but should get you started
Private Sub UIButtonControlAddField_Click()
    Dim sToolName As String
    sToolName = "Test Add Field"
    Dim pMxDoc As IMxDocument
    Dim pLayer As ILayer
    Dim pFeatureLayer As IFeatureLayer
    Dim pFeatureClass As IFeatureClass
    Dim pField As IField
    Set pMxDoc = Application.Document
    Set pLayer = pMxDoc.SelectedLayer
    ' Make sure some type of layer is selected
    If (pLayer Is Nothing) Then
        MsgBox "Please Select a feature layer.", vbOKOnly, sToolName
        Exit Sub
    End If
    ' Make sure a feature layer (not a group layer) is selected
    If Not (TypeOf pLayer Is IFeatureLayer) Then
        Exit Sub
    End If
    Set pFeatureLayer = pMxDoc.SelectedLayer
    Set pFeatureClass = pFeatureLayer.featureClass
    Set pField = MakeIntField("COUNT")
    AddFieldToFeatureClass pFeatureClass, pField
End Sub
Public Function MakeIntField(fieldName As String) As IField
    Dim pFieldEdit As IFieldEdit
    Set pField = New field
    Set pFieldEdit = pField
    pFieldEdit.Name = fieldName
    pFieldEdit.Type = esriFieldTypeInteger
    Set MakeIntField = pField
End Function
Public Sub AddFieldToFeatureClass(featureClass As IFeatureClass, field As IField)
    Dim schemaLock As ISchemaLock
    On Error GoTo ErrorHandler
    Set schemaLock = featureClass
    schemaLock.ChangeSchemaLock (esriSchemaLock.esriExclusiveSchemaLock)
    featureClass.AddField field
    schemaLock.ChangeSchemaLock (esriSchemaLock.esriSharedSchemaLock)
    Exit Sub
ErrorHandler:
End Sub
