I need to add Annotation Layers from .dwg and .dgn CAD files to arcmapAt first I used Block of code like this ESRI.ArcGIS.Geodatabase.IWorkspaceFactory pWorkspaceFact = new
ESRI.ArcGIS.DataSourcesFile.CadWorkspaceFactory();
//Open the workspace.
ESRI.ArcGIS.Geodatabase.IWorkspace pWorkspace = pWorkspaceFact.OpenFromFile
(workspace_path, 0);
ESRI.ArcGIS.Geodatabase.IFeatureWorkspace pFeatureWorkspace =
(ESRI.ArcGIS.Geodatabase.IFeatureWorkspace)pWorkspace;
IGroupLayer cl = new GroupLayerClass();
cl.Name = fc_name;
IAnnotationLayerFactory lf = new FDOGraphicsLayerFactory() as IAnnotationLayerFactory;
IAnnotationLayer al= lf.OpenAnnotationLayer(pFeatureWorkspace, null, System.String.Concat(fc_name,":Annotation"));
cl.Add(al as ILayer);
but this code generates Annotation Layer with broken emty datasource. And datasource cannot be set from CAD manually.There also is interface EngineCadAnnotationLayerFactory and CoClass EngineCadAnnotationLayerFactoryClass, but they only implement ILayerFactory interface, not the IAnnotationLayerFacory interface. This trouble makes unreachable OpenAnnotationLayer() method. Can anyone help me to find solution?
