How to access a Feature service hosted on arcgis.com which is shared only with particular groups or organization
3331
10-17-2014 09:41 AM
WasimQadir1
In my C# application, I am trying to access a Feature service which is hosted on arcgis.com. The feature service is shared only with a group or organization and is NOT public. How can I access this service in my client code. Here is my client code which throws an exception saying the Authentication Token required. I do have the token but dont how to use that token to be successfully able to use the service. This same code runs fine for services that are shared as PUBLIC.
               IPropertySet sipPS = new PropertySet();
        sipPS.SetProperty("DATABASE", layerUrl);
        IWorkspaceFactory sipWSF = (IWorkspaceFactory)new ESRI.ArcGIS.Carto.FeatureServiceWorkspaceFactory();
        IWorkspace sipWS = sipWSF.Open(sipPS, 0);
        IFeatureWorkspace sipFWS = (IFeatureWorkspace)sipWS;
        IGroupLayer grpLayer = new GroupLayerClass();
        grpLayer.Name = Constants.ArcGISOnlineGroupLayerName;
        IFeatureClass sipFC = sipFWS.OpenFeatureClass("0");
        IFeatureLayer fl = new FeatureLayerClass();
        fl.Name = featureLayerName;
        fl.FeatureClass = sipFC;
        grpLayer.Add(fl as ILayer);
LesleyBross
This doesn't answer Wasim's authentication question but I am grateful for his code sample. I was able to use it to connect to our homegrown ArcGIS feature services to create an IFeatureClass that I can work with in my ArcMap Add-In. Here is my VB .NET code:
    Public Function BA_OpenFeatureClassFromService(ByVal url As String, ByVal layerId As Integer) As IFeatureClass
        Dim sipPs As IPropertySet = New PropertySet()
        Dim sipWSF As IWorkspaceFactory = New FeatureServiceWorkspaceFactory()
        Dim sipWS As IWorkspace = Nothing
        Dim sipFws As IFeatureWorkspace = Nothing
        Try
            'Trim any data after "FeatureServer" in url
            Dim idxFs As Integer = url.IndexOf("FeatureServer")
            url = url.Substring(0, (idxFs + "FeatureServer".Length))
            sipPs.SetProperty("DATABASE", url)
            sipWS = sipWSF.Open(sipPs, 0)
            sipFws = CType(sipWS, IFeatureWorkspace)
            Dim strLayerId As String = CType(layerId, String)
            Return sipFws.OpenFeatureClass(strLayerId)
        Catch ex As Exception
            Debug.Print("BA_OpenFeatureClassFromService Exception: " & ex.Message)
            Return Nothing
        Finally
            sipPs = Nothing
            sipWS = Nothing
            sipFws = Nothing
            GC.WaitForPendingFinalizers()
            GC.Collect()
        End Try
    End Function
