How do I load Raster Mapcache data to my ArcGIS 10.2. SDK for Window Mobile application?
1246
02-05-2016 01:00 PM
I created the vector and raster mapcache data using the "Create Mobile Cache" tool of the "Mobile Tools" within ArcCatalog.
This application is created with ArcGIS 10.2.2 SDK for Windows Mobile.
I don’t have any problems loading the Vector mapcache data which are recognized as map layers.
But I’m having problems loading the Raster mapcache data which seem not to be map layer based.
' --- Load the Raster MapCache  -  Not Working
RasterMapCache.StoragePath = Trim(m_OrthoLocalStoragePath)
If RasterMapCache.CacheExists Then
   ' --- Open the Raster MapCache
   RasterMapCache.Open()
   ' --- Add Raster MapCache to Map as (Map Layers)  -  ???
   Me.Map1.MapLayers.Add(RasterMapCache)  'Not Working - Crashing at this statement
End If
' --- Load the Vector MapCache  -  Working Fine
VectorMapCache.StoragePath = Trim(m_MapCacheLocalStoragePath)
If VectorMapCache.CacheExists Then
   ' --- Open the Vector MapCache
   VectorMapCache.Open()
   ' --- Add Vector MapCache to Map as Map Layers
   Me.Map1.MapLayers.Add(VectorMapCache)
End If
Reply
To answer my own question.
Because our raster data is Tiled in ArcGIS 10.2.2 I had to modify my code.
' --- Tiled Mapcache Data
Try
' --- Assign path of Tile Cache location to string path object
 Dim TCMapLayer As TileCacheMapLayer = New TileCacheMapLayer(m_OrthoLocalStoragePath + "\Layers")
' --- Assign name of Tile Cache Maplayer and make it visible
TCMapLayer.Name = "2015 Orthos"
TCMapLayer.Visible = True
' --- Open the Tile Cache Maplayer
TCMapLayer.Open()
' --- Add the Tile Cache Maplayer to the map
Map1.MapLayers.Add(TCMapLayer)
Catch ex As Exception
MessageBox.Show("Cannot open map cache" & vbCr & vbCr & _
"Error Message: " & ex.ToString)
End Try
Reply
Try
TCMapLayer.Open()
End Try
Reply
