I would like to show the identify of a IFeatureLayer in ArcMap's Identify window.
I had used IdentifyDialog to create a custom dialog to show the identify,
but it seems that the ArcMap's identify window has more functionality then custom dialog.
So I wonder that if I can use some method to open ArcMap's identify window.
Li
You can call the ArcMap Identify Tool command programmatically by using the following GUID/Class ID
{CF605583-AEA3-41D8-9464-DDD1905243D9}
esriControls.ControlsMapIdentifyTool
See the following list for a list of the ArcMap Command GUIDs:
See the following code snippet for an example on how to call an ArcMap command programmatically:
ArcObjects Help for .NET developershttp://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#/Find_Command_and_Execut...
