For z = 0 To pMap.LayerCount - 1 pLayerCheck = pMap.Layer(z) Call recursiveSearch(pLayerCheck) Next z
Public Sub deleteGroupLayer(ByVal pLayer As ILayer) Dim pMxDoc As IMxDocument Dim pMap As IMap Dim pTempLayer As ICompositeLayer pMxDoc = My.ArcMap.Document pMap = pMxDoc.FocusMap If TypeOf pLayer Is ICompositeLayer Then pTempLayer = pLayer If pTempLayer.Count = 0 Then pMap.DeleteLayer(pLayer) End If End If End Sub Public Sub recursiveSearch(ByVal pLayer As ILayer) Dim bContinue As Boolean bContinue = True Dim iLayerCount As Integer If Not TypeOf pLayer Is ICompositeLayer Then Exit Sub Else Dim pCompLayer As ICompositeLayer Dim pSubLayer As ILayer pCompLayer = pLayer iLayerCount = pCompLayer.Count For SubLayerIndex = 0 To iLayerCount - 1 pSubLayer = pCompLayer.Layer(SubLayerIndex) recursiveSearch(pSubLayer) Call deleteGroupLayer(pSubLayer) Next SubLayerIndex End If End Sub
Hi all,
I will spare the details of why my map has several empty group layers unless anyone is interested, though it's not likely to be relevant at this point. We have a map of group layers with several more sets of nested group layers within (to keep similar datasets organized).
I'm trying to set something up to loop through the entire table of contents (say, 6 major group layers), check if a group layer is empty (i. e. contains no feature layers), if it is remove it, otherwise do nothing.
I'll post the code below, and the error I'm getting is "Value does not fall within the expected range" which I'm guessing means that the For loop is breaking (in: Public Sub recursiveSearch(ByVal pLayer As ILayer))
. My theory is that deleting the group layer takes the total count down by 1, thus having the for loop sitting at z = 2 when the pMap.LayerCount - 1 is only 1 now. But that's a working theory 😛
In the main part of the code:For z = 0 To pMap.LayerCount - 1 pLayerCheck = pMap.Layer(z) Call recursiveSearch(pLayerCheck) Next z
Basically, send each major group layer to the functions below. Any assistance is appreciated and please let me know if more info is required.
Thank you!Public Sub deleteGroupLayer(ByVal pLayer As ILayer) Dim pMxDoc As IMxDocument Dim pMap As IMap Dim pTempLayer As ICompositeLayer pMxDoc = My.ArcMap.Document pMap = pMxDoc.FocusMap If TypeOf pLayer Is ICompositeLayer Then pTempLayer = pLayer If pTempLayer.Count = 0 Then pMap.DeleteLayer(pLayer) End If End If End Sub Public Sub recursiveSearch(ByVal pLayer As ILayer) Dim bContinue As Boolean bContinue = True Dim iLayerCount As Integer If Not TypeOf pLayer Is ICompositeLayer Then Exit Sub Else Dim pCompLayer As ICompositeLayer Dim pSubLayer As ILayer pCompLayer = pLayer iLayerCount = pCompLayer.Count For SubLayerIndex = 0 To iLayerCount - 1 pSubLayer = pCompLayer.Layer(SubLayerIndex) recursiveSearch(pSubLayer) Call deleteGroupLayer(pSubLayer) Next SubLayerIndex End If End Sub
