GetAllProperties on Propertyset is slow for line network data
2397
10-28-2015 08:36 AM
jayshukla
New Contributor III
Hi There,
I am trying to resolve an issue with an ArcObjects extension. This particular portion of logic, gathers metadata for layers in the map. It works fine with regular data layers but with network data (pipeline network layer), it takes much longer than expected. The point layers participating (exp: wells, facilities, pipelines nodes) within network are fine, it's only the pipeline (line) that takes longer. This impacts user workflow when they are trying to switch data frames (one with network data and other with schematics data). Initially i thought that it was related to missing metadata but adding metadata didn't help resolve this issue. I am looking for some suggestions on what may be the workaround for this issue. Our environment is ArcGIS 10.2.2, VB.NET, .NET4 code base. Below is the code.
Appreciate any input.
Thanks
Jay
Dim pMD As IMetadata
Dim pPS As IPropertySet
pDLayer = CType(pLayer, IDataLayer)
pMD = CType(pDLayer.DataSourceName.Open, IMetadata)
If Not pMD Is Nothing Then
  Dim vaValues As Object
    Dim v As Object
    Dim valuesArray As System.Array
    pPS = New PropertySet
    pPS = pMD.Metadata
    Dim tnames As Object
    Dim tvalues As Object
    Dim vFormat As Object
    'Return the metadata elements
    pPS.GetAllProperties(tnames, tvalues) - code takes much longer for pipeline data
DuncanHornby
MVP Notable Contributor
What gets returned in ​tnames​ and ​tvalues​? Does it contain what you expected, despite it being slow?
jayshukla
New Contributor III
Yes, the code returns what is expected. tnames & tvalues objects contain are all the values in the property set. Below is the code that shows how the code is being used. I looked up ESRI help, link here: ArcObjects Help for .NET developers.
If Not pPS Is Nothing Then
       vaValues = pPS.GetProperty("idinfo/keywords/theme/themekey")
       'Check for different xml tag for ArcGIS 10 metadata
       If IsNothing(vaValues) Then vaValues = pPS.GetProperty("dataIdInfo/themeKeys/keyword")
        If Not IsNothing(vaValues) Then
            valuesArray = CType(vaValues, System.Array)
            For Each v In valuesArray
                If InStr(CType(v, String), "HUK") > 0 Then
                      returnArray.Add(CType(v, String))
                 End If
       End If
End If
jayshukla
New Contributor III
Hi, I still don't have a solution for this issue, wondering if there are any other suggestions from fellow members. Thanks in advance.
Jay
