I have searched a lot of forums looking for answers but none have helped so far.
I am trying to run my own script ( a dummy empty one for now) with geoprocessing in Visual studio 2010 using c# and ArcDesktop 10. When I ran this with the "Buffer_analysis" built in tool and some different parameters it worked fine. When I run my own script (which i know it sees as i print the tools out) i can't even get gp.GetMessage(0) error messages, they just come up blank.
Here is my c#.net code:
using ESRI.ArcGIS.Geoprocessing;
GeoProcessor gp = new GeoProcessor();
ESRI.ArcGIS.esriSystem.AoInitialize ao = null;
try
RuntimeManager.Bind(ProductCode.Desktop);
ao = new AoInitializeClass();
esriLicenseStatus licStatus = ao.Initialize(esriLicenseProductCode.esriLicenseProductCodeEngine); //Ive also tried arcEditor liscence
ao.CheckOutExtension(esriLicenseExtensionCode.esriLicenseExtensionCode3DAnalyst);
Debug.WriteLine("License Checkout successful.");
gp.OverwriteOutput = true;
gp.AddToolbox(@"C:\MyToolbox.tbx");
IGpEnumList tools = gp.ListTools("*");
string tool = tools.Next();
while (tool != "")
Debug.WriteLine(tool);
IVariantArray parameters = new VarArrayClass();
parameters.Add(@"C:\Custom_Menu\shape.shp");
gp.Execute("test", parameters, null);//*********************************this gives the error***************************************
catch... Debug.WriteLine(gp.GetMessage(0))
Here is my "test.py" script:
# Import arcpy module
import arcpy, os
from arcpy import env
arcpy.AddMessage( "\nDone")
I don't get it. Please help...
