Extract Spatial ID from a Polygon
799
04-20-2021 11:30 AM
rajujee
I am new to ArcObjects, I am spinning my wheels extracting Spatial ID from a polygon. I have a features with 100 blocks when I add a point features on polygon feature. I need its ID.
Any help or link is appreciated.
R
BrentHoskisson
You need to spend more time constructing your question so it will be understood.  It appears you are trying to to search polygons with a point feature.  If this is so you want to start by creating a spatial filter
Here is a sample that is set up to intersect:
 public static ISpatialFilter CreateSpatialFilter(IFeatureClass fc, IGeometry shape)
            if (fc == null) return null;
            ISpatialFilter sf = new SpatialFilterClass();
            sf.GeometryField = fc.ShapeFieldName;
            sf.Geometry = shape;
            sf.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects;
            return sf;
Then you can use this directly on your feature class using the Search function..
IFeatureCursor fcursor = fc.Search(CreateSpatialFilter(fc, shape), true);
Now index through the cursor to get the polygon id's.
Good Luck
Brent Hoskisson
rajujee
This worked as a charm. Thanks Brent.
