Exception while creating the schematic diagram for selected features?
2902
07-19-2014 11:01 PM
SreerajanParamanandham1
New Contributor II
I am trying to generate schematic using the below code, this code is working fine to generate schematic for logical data. But the same code is raising exception "while creating the schematic for selected featues in map". I have used the"Geo initial position" layou.
Please help me to resolve this isse.
Type factoryType = Type.GetTypeFromProgID("esriDataSourcesGDB.AccessWorkspaceFactory");
IWorkspaceFactory sWorkspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(factoryType);
IWorkspace sWorkspace = sWorkspaceFactory.OpenFromFile(@"xxxxxx.mdb", 0);
ISchematicWorkspaceFactory oSchematicWorkspaceFactory = new SchematicWorkspaceFactory();
ISchematicWorkspace sSchematicWorkspace = oSchematicWorkspaceFactory.Open(sWorkspace);
ISchematicDataset sSchematicDataset = sSchematicWorkspace.get_SchematicDatasetByName("TestDataset");
ISchematicDiagramClassContainer oSchDiagramClassContainer = (ISchematicDiagramClassContainer)sSchematicDataset;
ISchematicDiagramClass sSchematicDiagramClass = oSchDiagramClassContainer.GetSchematicDiagramClass("TestTemplate");
ISchematicBuilder sSchematicBuilder;
ISchematicStandardBuilder sSchematicStandardBuilder;
Type.GetTypeFromProgID("esriSchematic.SchematicStandardBuilderContext");
Activator.CreateInstance(objClassType);
ISchematicBuilderContext sSchematicBuilderCtxt = (ISchematicBuilderContext)objApp_Late;
ISchematicBuilder)sSchematicDiagramClass;
ISchematicStandardBuilder)sSchematicDiagramClass.SchematicBuilder;
sSchematicStandardBuilder.InitializeLinksVertices = false;
sSchematicStandardBuilder.AutoCreateElementClasses = true;
ITrackCancel oTrackCancel = new TrackCancelClass();
ISchematicDiagramContainer)sSchematicDataset;
objSchemaDiag = sSchematicBuilder.GenerateDiagram("xxxxx", pSchematicDiagramContainer, null, sSchematicBuilderCtxt, oTrackCancel); //Exception raised
Exception in Generate diagram
COMException was CaughtError
HRESULT E_FAIL has been returned from a call to a COM component.
Regareds
Sreerajan P
Anne-YvonneBlin
New Contributor III
It looks like you didn't initialize the ISchematicStandardBuilderContext with the selected features set in the map.
#region"Generate A Diagram From A Map Selection"
// ArcGIS Snippet Title:
// Generate A Diagram From A Map Selection
// Long Description:
// Generate a diagram from features selected in a geographic map
// Add the following references to the project:
// ESRI.ArcGIS.Carto
// ESRI.ArcGIS.Schematic
// Intended ArcGIS Products for this snippet:
// ArcGIS Desktop (Standard, Advanced)
// ArcGIS Engine
// Applicable ArcGIS Product Versions:
// 10.0
// 10.1
// Required ArcGIS Extensions:
// ArcGIS Schematics
// Notes:
// This snippet is intended to be inserted at the base level of a Class.
// It is not intended to be nested within an existing Method.
/// <summary>
/// Generate a diagram from features selected in a geographic map
/// </summary>
/// <param name="pMap">Geographic map containing the input selected GIS features</param>
/// <param name="schemDiagClass">SchematicDiagramClass; that is, diagram template on which the generated diagram is based</param>
/// <param name="schemDiagramContainer">SchematicDiagramContainer where the generated diagram will be stored</param>
/// <param name="DiagramName">Name for the generated diagram</param>
/// <returns>ESRI.ArcGIS.Schematic.ISchematicDiagram</returns>
///<remarks></remarks>
public ESRI.ArcGIS.Schematic.ISchematicDiagram GenerateDiagramFromMap(ESRI.ArcGIS.Carto.IMap pMap, ESRI.ArcGIS.Schematic.ISchematicDiagramClass schemDiagClass, ESRI.ArcGIS.Schematic.ISchematicDiagramContainer schemDiagramContainer, string DiagramName)
  // if DiagramName is empty exit
  if (DiagramName.Length == 0) return null;
    // cast SchematicDiagramClass into ISchematicBuilder
  ESRI.ArcGIS.Schematic.ISchematicBuilder schBuilder = (ESRI.ArcGIS.Schematic.ISchematicBuilder)schemDiagClass;
    // create the ISchematicStandardBuilderContext
  Type objectType = Type.GetTypeFromProgID("esriSchematic.SchematicStandardBuilderContext");
  // if objectType is null, the BuilderContext cannot be created, then exit
  if (objectType == null) return null;
  ESRI.ArcGIS.Schematic.ISchematicStandardBuilderContext schBuilderCtxt;
  schBuilderCtxt = Activator.CreateInstance(objectType) as ESRI.ArcGIS.Schematic.ISchematicStandardBuilderContext;
    // get the selected features in the map
  ESRI.ArcGIS.Geodatabase.IEnumFeature enumFeature = (ESRI.ArcGIS.Geodatabase.IEnumFeature)pMap.FeatureSelection;
    // initialize the ISchematicStandardBuilderContext with the selection set
  schBuilderCtxt.InitialObjects = new EnumSchematicObject(enumFeature);
  // generate the schematic diagram
    ESRI.ArcGIS.Schematic.ISchematicDiagram GeneratedDiagram = schBuilder.GenerateDiagram(DiagramName, schemDiagramContainer, null, (ESRI.ArcGIS.Schematic.ISchematicBuilderContext)schBuilderCtxt, null);
    return GeneratedDiagram;
public class EnumSchematicObject : ESRI.ArcGIS.Geodatabase.IEnumObject
  private ESRI.ArcGIS.Geodatabase.IEnumFeature m_pIEnumFeature;
  public EnumSchematicObject(ESRI.ArcGIS.Geodatabase.IEnumFeature pEnumFeature)
        m_pIEnumFeature = pEnumFeature;
  public ESRI.ArcGIS.Geodatabase.IObject Next()
  if (m_pIEnumFeature != null)
  return (ESRI.ArcGIS.Geodatabase.IObject)m_pIEnumFeature.Next();
  else
  return null;
  public void Reset()
  if (m_pIEnumFeature != null) m_pIEnumFeature.Reset();
#endregion
Anne-YvonneBlin
New Contributor III
// ArcGIS Engine
// 10.0
// 10.1
// Notes:
/// <summary>
/// </summary>
  else
  return null;
  public void Reset()
#endregion
New Contributor II
Thanks you very much Anne-Yvonne Blin, This is working fine .
