ESRI.ArcGIS.Geoprocessor.Geoprocessor unable to release memory
1771
11-26-2018 02:10 AM
umasuryasykam1
Below script is very standard for running any geoprocessing tool using ArcObjects but it hardly releases memory. It is helping the tool crashes after processing few 100 datasets. Please help in this regard. Thanks in advance.
geoprocessor.ClearMessages();
// Set the overwrite output option to true
geoprocessor.OverwriteOutput = true;
try
Logger.Write("RunTool is started", "AppLog");
// Execute the tool
geoprocessor.Execute(process, null);
ReturnMessages(geoprocessor);
ESRI.ArcGIS.ADF.ComReleaser.ReleaseCOMObject(geoprocessor);
ESRI.ArcGIS.ADF.ComReleaser.ReleaseCOMObject(process);
geoprocessor = null;
process = null;
catch (Exception ex)
Logger.Write("Exception in RunTool::"+ex.Message, "ExceptionHandling");
DuncanHornby
MVP Notable Contributor
You seemed to have neglected to say what exactly it is you are running? What is process in geoprocessor.Execute(process, null)? What Tool is it and what where the supplied parameters?
umasuryasykam1
I missed it accidentally just  due to considered it as abstraction as it happened for all types of operations in general such as 'Project', 'Merge' etc. Few others we moved to use plain arcobjects using c# related to geodatabase.
The other parameters would be shapefile paths depending on the parameters require for a given operation.
MilanasSkačkauskas1
@umasurya sykam First of all - your code missing "finally" block. You need to realease all COM objects int it. So if exception occurs in some situations - it always release COM objects and it's memory. For example:
Geoprocessor geoprocessor = null;
Process  process= null;
try
geoprocessor = new Geoprocessor();
process =  new Process();
catch()
finaly
if(geoprocessor != null)
geoprocessor =null;
if(process != null)
ESRI.ArcGIS.ADF.ComReleaser.ReleaseCOMObject(process );
process =null;
umasuryasykam1
Although I'm not releasing within finally block, they are being released within the try block itself properly and those 2 lines of code always get executed. But memory is not being recovered after that.
Another question I have is normally we are releasing eari COM objects using Marshal.ReleaseComObject.
Is the Geoprocessor class not a COM object?
MilanasSkačkauskas1
You need to check if it is COM object, if not - check if it is IDisposable. I have smart function for that:
public static int Release(object comObj)
   try
      if (comObj != null)
         if (Marshal.IsComObject(comObj))
            try
               return Marshal.ReleaseComObject(comObj);
            catch
               comObj = null;
         else
            var disposable = comObj as IDisposable;
            if (disposable != null)
               disposable.Dispose();
               return 0;
      System.Diagnostics.Debug.WriteLine("CATCH: " + ex.Message);
   return -999;
How to use function:
finally
   if (geoprocessor != null)
      Release(geoprocessor);
      geoprocessor= null;
