'Error HRESULT E_FAIL has been returned from a call to a COM component' get selected.
796
11-04-2013 07:39 AM
kju
Post my code at first:
 #region Member.
        private AxMapControl _MapCon = null;    //MapControl from the main form.
        private IGeometry _BufferResult = null;
        #endregion
        public FrmBufferAnalyst(AxMapControl mapControl) {
            this._MapCon = mapControl;
            InitializeComponent();
        private void FrmBufferAnalyst_Load(object sender, EventArgs e) {
            ShowSelectedFeatures();
        /// <summary>
        /// //Show selected feature.
        /// </summary>
        void ShowSelectedFeatures() {
            lbox_selectedFeature.Items.Clear();
            ISelection fSelection = this._MapCon.Map.FeatureSelection;
            IEnumFeature enumF = (IEnumFeature)fSelection;
            IFeature f = null;
            while((f = enumF.Next()) != null) {
                lbox_selectedFeature.Items.Add("Feature layer:" + f.Class.AliasName);
                lbox_selectedFeature.Items.Add("OID:" + f.OID);
                lbox_selectedFeature.Items.Add("-----");    //Separator.
Before,I used the same project to execute buffer analyst,such as compute the area or query feature within the buffered feature.It works well.
But now,when I select the specifed feature and past them into another form and load.But it throws exception when trying to get the 'OID' property.Is something wrong with my code?Thanks.
DuncanHornby
MVP Notable Contributor
If the error is occurring on the line:
Then it may be a type conversion error as OID will return an Integer. SO in VB I would do something like:
lbox_selectedFeature.Items.Add("OID:" + f.OID.ToString())
kju
Thanks for your response but,It shouldn't that issue, 'f.OID' cencerns nothing with the exception.when debuging,'f' exsist but throws exception when get it's OID property.
BruceNielsen
Does f.HasOID return True?
