public static void LoadDemo()
try
IWorkspaceName sourceWorkspaceName = (IWorkspaceName)new WorkspaceName();
sourceWorkspaceName.PathName = @"C:\Crip\trichluc";
sourceWorkspaceName.WorkspaceFactoryProgID = "esriDataSourcesFile.ShapefileWorkspaceFactory.1";
IWorkspaceName targetWorkspaceName;
Type t = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory.1");
IWorkspaceFactory pFactory = (IWorkspaceFactory)Activator.CreateInstance(t);
if (File.Exists(@"C:\Crip1\load.sde"))
IWorkspace workspace = pFactory.OpenFromFile(@"C:\Crip1\load.sde", 0);
IDataset ids = (IDataset)workspace;
targetWorkspaceName = (IWorkspaceName)ids.FullName;
else
IPropertySet propertySet = new PropertySetClass();
propertySet.SetProperty("SERVER", "hpserver");
propertySet.SetProperty("INSTANCE", "5151");
propertySet.SetProperty("DATABASE", "sde");
propertySet.SetProperty("USER", "sde");
propertySet.SetProperty("PASSWORD", "12345678");
propertySet.SetProperty("VERSION", "dbo.DEFAULT");
targetWorkspaceName = pFactory.Create(@"C:\Crip1", "load.sde", propertySet, 0);
// Create a name object for the source feature class.
IFeatureClassName sourceFeatureClassName = (IFeatureClassName)new FeatureClassName();
IDatasetName sourceDatasetName = (IDatasetName)sourceFeatureClassName;
sourceDatasetName.WorkspaceName = sourceWorkspaceName;
sourceDatasetName.Name = "87884606.shp";
IFeatureDatasetName featDSName = new FeatureDatasetName() as IFeatureDatasetName;
IDatasetName DSName = (IDatasetName)featDSName;
DSName.WorkspaceName = targetWorkspaceName;
DSName.Name = "test";
IFeatureClassName targetFeatureClassName = (IFeatureClassName)new FeatureClassName();
IDatasetName targetDatasetName = targetFeatureClassName as IDatasetName;
targetDatasetName.WorkspaceName = targetWorkspaceName;
targetDatasetName.Name = "load_demo";
// Open the source feature class to get field definitions.
IName sourceName = (IName)sourceDatasetName;
IFeatureClass sourceFeatureClass = (IFeatureClass)sourceName.Open();
// Open the two workspaces for the field validator.
IName sourceIName = (IName)sourceWorkspaceName;
IName targetIName = (IName)targetWorkspaceName;
IWorkspace sourceWorkspace = (IWorkspace)sourceIName.Open();
IWorkspace targetWorkspace = (IWorkspace)targetIName.Open();
// Use a field checker for field validation.
IFieldChecker fieldChecker = new FieldChecker();
IFields sourceFields = sourceFeatureClass.Fields;
fieldChecker.InputWorkspace = sourceWorkspace;
fieldChecker.ValidateWorkspace = targetWorkspace;
IEnumFieldError enumFieldError = null;
IFields outputFields = null;
fieldChecker.Validate(sourceFields, out enumFieldError, out outputFields);
// If any field validation errors occurred, they can be viewed at this point.
// Get the GeometryDef from the source feature class and modify it.
// Note that this only modifies the object in memory, and will not effect the source data.
int shapeFieldIndex = sourceFeatureClass.FindField(sourceFeatureClass.ShapeFieldName);
IField shapeField = sourceFields.get_Field(shapeFieldIndex);
IGeometryDef geometryDef = shapeField.GeometryDef;
IGeometryDefEdit geometryDefEdit = (IGeometryDefEdit)geometryDef;
geometryDefEdit.GridCount_2 = 1;
geometryDefEdit.set_GridSize(0, 1500000);
// Load the feature class.
IFeatureDataConverter featureDataConverter = (IFeatureDataConverter)new FeatureDataConverter();
try
featureDataConverter.ConvertFeatureClass(sourceFeatureClassName,
null, featDSName, targetFeatureClassName, geometryDef, outputFields, "", 1000, 0);
catch (Exception exp)
MessageBox.Show(exp.ToString());
//throw;
// If any invalid features were encountered during conversion, they can be
// displayed by iterating through the enumInvalidObject enumerator.
catch (Exception ex)
MessageBox.Show(ex.ToString());
