Count features intersecting buffered geometry - memory leak
2893
12-01-2014 10:57 AM
AndyMarchant
Hi All,
I'm calling the function below several thousand times, but it just seems to increase memory usage until it falls over. I've tried Marshal.ReleaseComObject and ComReleaser without any luck. It seems to be related to the buffered geometry as if I give the non buffered geometry (SiteGeometry) to pSpatialFilter it seems fine.
Any ideas how i release the memory used by this function?
thanks,
Andy
Public Function doSearch(ByVal SiteGeometry As IGeometry, ByVal SearchLayer As IFeatureClass, ByVal Buffer As Integer, ByVal shapeField As String) As Integer
        Dim topoOP As ITopologicalOperator2
        Dim pSpatialFilter As ISpatialFilter = New SpatialFilter
        topoOP = SiteGeometry
        topoOP.Simplify()
        Dim pGeometryBuff As IGeometry = topoOP.Buffer(Buffer)
        With pSpatialFilter
            .Geometry = pGeometryBuff
            .GeometryField = shapeField
            .SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects
        End With
        Dim theRowcount As Integer = SearchLayer.FeatureCount(pSpatialFilter)
        topoOP = Nothing
        pSpatialFilter = Nothing
        pGeometryBuff = Nothing
        pBC = Nothing
        Return theRowcount
    End Function
DuncanHornby
MVP Notable Contributor
Your code looks OK to me. Don't know if this will help but maybe you can pass in siteGeometry and SearchLayer as "ByRef" rather than "ByVal"?
RiverTaig1
I would try using the SelectionSet method and getting the count off of that. Don't forget to call FinalReleaseComObject on selSet.
IWorkspace ws = ((IDataset)SearchLayer).Workspace;
ISelectionSet selSet = SearchLayer.Select(pSpatialFilter, esriSelectionType.esriSelectionTypeIDSet, esriSelectionOption.esriSelectionOptionNormal, ws);
int rowCount = selSet.Count;
Marshal.FinalReleaseComObject(selSet);
Good luck.
AndyMarchant
thanks for your suggestions - i eventually managed to reduce the memory leak to an acceptable trickle using comReleaser. Final code is below:
Public Function doSearch(ByVal SiteGeometry As IGeometry, ByVal SearchLayer As IFeatureClass, ByVal Buffer As Integer, ByVal shapeField As String, ByVal thewhere As String) As Boolean
        Using comReleaser As ComReleaser = New ComReleaser()
            Dim topoOperator As ITopologicalOperator = CType(SiteGeometry, ITopologicalOperator)
            comReleaser.ManageLifetime(topoOperator)
            Dim buffer2 As IGeometry
            If Buffer = 0 Then
                buffer2 = SiteGeometry
            Else
                buffer2 = topoOperator.Buffer(Buffer)
            End If
            comReleaser.ManageLifetime(buffer2)
            Dim spatialFilter As ISpatialFilter = New SpatialFilterClass()
            comReleaser.ManageLifetime(spatialFilter)
            spatialFilter.Geometry = buffer2
            spatialFilter.GeometryField = shapeField
            spatialFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects
            spatialFilter.WhereClause = thewhere
            ' Execute the query.
            Dim featureCursor As IFeatureCursor = SearchLayer.Search(spatialFilter, True)
            comReleaser.ManageLifetime(featureCursor)
            Dim feature As IFeature = featureCursor.NextFeature()
            comReleaser.ManageLifetime(feature)
            If feature Is Nothing Then
                Return False
            Else
                Return True
            End If
        End Using
    End Function
