Couldn`t  load a data from a Geodatabase using the AddDataCommand in vb.net From?
895
03-10-2014 05:29 AM
dgesridgesri
Occasional Contributor II
Greetings,
I`m trying to develop a form in vb.net 2010 that contains ArcEngine MapControl, TOCControl, & ToolbarControl in order to load a data in the map control and view it using the commands in the toolbar control...
I used the following:
 Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load          AxTOCControl1.SetBuddyControl(AxMapControl1)         AxToolbarControl1.SetBuddyControl(AxMapControl1)          'Add generic commands.         AxToolbarControl1.AddItem("esriControls.ControlsOpenDocCommand", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsAddDataCommand", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)          'Add page layout navigation commands.         AxToolbarControl1.AddItem("esriControls.ControlsPageZoomInTool", -1, -1, True, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsPageZoomOutTool", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsPagePanTool", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsPageZoomWholePageCommand", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         'Add map navigation commands.         AxToolbarControl1.AddItem("esriControls.ControlsMapZoomInTool", -1, -1, True, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsMapZoomOutTool", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsMapPanTool", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsMapFullExtentCommand", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsMapZoomToLastExtentBackCommand", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsMapZoomToLastExtentForwardCommand", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         'Add map inquiry commands.         AxToolbarControl1.AddItem("esriControls.ControlsMapIdentifyTool", -1, -1, True, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsMapFindCommand", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)         AxToolbarControl1.AddItem("esriControls.ControlsMapMeasureTool", -1, -1, False, 0, esriCommandStyles.esriCommandStyleIconOnly)     End Sub
At the runtime when I tried to load a geodatabase, and exactly when I tried to access a personal geodatabase I got the following error:
"Couldn't connect to the database.  Please validate the integrity of the database and/or your network connection and try again."
Please advise !!
Thanks in advance...
dgesridgesri
After posting this form, I tried to add the AxLicenseControl and I select ArcEngine license from the properties and everything went smooth...
Thanks...
dgesridgesri
Thanks...
