Hi,i have a problem with the CopyRaster geoprocessing tool. When I use the GP-Tool to execute it with the Geoprocessor object, it keeps 2 open cursors on my Oracle SDE. I have to copy many rasters from a local folder to the geodatabase. After some time I get ORA-0100: Maximum open cursors exceeded because the open cursors do not get closed until I close ArcMap (i am developing an ArcMap extension with C#). I have tried some things to free the c#-objects, but this does not close the open cursors. What can I do?Here is the code which I use to copy the rasters from the file system to the Oracle SDE: var files = new Dictionary<string, string>();
/* read directory structure and collect all BMP files */
foreach (var file in files)
var fullRasterSourcePath = file.Key;
var fullRasterSDE = @"Database Connections\vsdev0920.sde\MARA." + file.Value;
var cpRas = new ESRI.ArcGIS.DataManagementTools.CopyRaster
in_raster = fullRasterSourcePath,
out_rasterdataset = fullRasterSDE,
nodata_value = 0
var gp = new ESRI.ArcGIS.Geoprocessor.Geoprocessor();
gp.Execute(cpRas, null);
ESRI.ArcGIS.ADF.ComReleaser.ReleaseCOMObject(gp);
ESRI.ArcGIS.ADF.ComReleaser.ReleaseCOMObject(cpRas);
mygp = null;
cpRas = null;
GC.Collect();
GC.WaitForPendingFinalizers();
GC.Collect();
After every execution of the CopyRaster tool, there are 2 more open cursors which I checked with the following SQL statement:select sum(a.value) total_cur, avg(a.value) avg_cur, max(a.value) max_cur,
s.username, s.machine
from v$sesstat a, v$statname b, v$session s
where a.statistic# = b.statistic# and s.sid=a.sid
and b.name = 'opened cursors current'
group by s.username, s.machine
order by 1 desc;
Both client and SDE are at ArcGIS level 9.3.1 SP2Best regards, Stefan
