Convert Editor IEditTask --> AddIns.Extension and get it as IEditTask on runtime
2825
07-29-2019 12:41 AM
MarkMindlin
We convert old custom COM tools to custom AddIns and have a question - how to get it as IEditTask on runtime?
We need to set Application.CurrentTask with ESRI.ArcGIS.Editor.IEditTask, so the question is how to create an object with type IEditTask?
Old COM class:
   public class clsCustomEditTask : ESRI.ArcGIS.Editor.IEditTask
New AddIn class:
   public class clsCustomEditorExtension : ESRI.ArcGIS.Desktop.AddIns.Extension
The help says we cannot deploy (register) tasks in AddIn
See
ArcObjects Help for .NET developers
ArcMap 10.6.1, C#
by Anonymous User
Not applicable
Nope. The add-in framework was designed to simplify common control creation and deployment (tools, commands, toolbars, menus etc).
To rewrite your edit task as an add-in you could port the code over as a tool.
by Anonymous User
Not applicable
Hi Mark,
I would like to understand the requirement, before helping you out. Could you please detail the requirement.
However, please have a look into the below link.
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#/IEditTaskSearch_Interfa...
Thanks.
MarkMindlin
Thanks Fayaz Baig
The link you provided did not helped.
Let do questions:
1. Is it possible to convert COM class:
to AddIn?
2. Please send example (of an AddIn that contains IEditTask).
MarkMindlin
It looks like there is no way to convert it
by Anonymous User
Not applicable
