convert decimal degree to km or meters
18027
05-22-2013 05:56 AM
VsU
Hi.
Sorry for my bad English.
Can I convert length direct line fragment from  decimal degree to km or meters
I tried used IUnitConverter, but in ConvertUnits method, does not provide information about latitude and the result is not correct.
AlexanderGray
Regular Contributor II
Angles don't convert to distance directly.  The length of a line fragment expressed in degrees is pretty much meaningless.  You need the start and end point of your line fragment to be able to get the length in a meaningful unit.  The IMeasurementTool allows you to construct a geodesically correct line and get the distance if you provide the spatial reference.
VsU
Thank you.
I use arcgis engine 9.3
Do I have Military Analyst 9.3 for the operation?
Can I free version Military Analyst 9.3 from site esri?
I have not found on the website of Military Analyst 9.3.
AlexanderGray
http://www.esri.com/software/arcgis/defense-solutions/download-ma
First page googling "Military Analyst 9.3"
I don't bother with esri's search boxes on their website anymore, I can usually find what I am looking for much faster googling esri key words.
