Conflict between VBA and/or Microsoft Office Shared Library and Add Data control
2906
05-03-2011 11:50 AM
MahdiRahimi
I've posted a thread about appcrash error in using Add Data control or setting Layers in MapControl properties window when there is an instance of office 2010 installed. I've found that VBA and/or Microsoft Office Shared Library causes the problem. Today I install VBA SDK and re-register office shared library and the error arise again. After installing VBA SDK two items Picture and Color are added to MapControl properties window.
MahdiRahimi1
Appcrash on vshost32.exe in using Add Data Control.
Visual Studio Output:
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\mscorlib\2.0.0.0__b77a5c561934e089\mscorlib.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\Microsoft.VisualStudio.HostingProcess.Utilities\9.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualStudio.HostingProcess.Utilities.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\Microsoft.VisualStudio.HostingProcess.Utilities.Sync\9.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\Microsoft.VisualStudio.Debugger.Runtime\9.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualStudio.Debugger.Runtime.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Users\Admin\Documents\Visual Studio 2008\Projects\MapControlApplication16\MapControlApplication16\bin\Debug\MapControlApplication16.vshost.exe', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\ESRI.ArcGIS.ADF.Local\10.0.0.0__8fc3cc631e44ad86\ESRI.ArcGIS.ADF.Local.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\ESRI.ArcGIS.Version\10.0.0.0__8fc3cc631e44ad86\ESRI.ArcGIS.Version.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\ESRI.ArcGIS.AxControls\10.0.0.0__8fc3cc631e44ad86\ESRI.ArcGIS.AxControls.dll'
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\ESRI.ArcGIS.Carto\10.0.0.0__8fc3cc631e44ad86\ESRI.ArcGIS.Carto.dll'
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\ESRI.ArcGIS.Controls\10.0.0.0__8fc3cc631e44ad86\ESRI.ArcGIS.Controls.dll'
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\ESRI.ArcGIS.Display\10.0.0.0__8fc3cc631e44ad86\ESRI.ArcGIS.Display.dll'
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\ESRI.ArcGIS.System\10.0.0.0__8fc3cc631e44ad86\ESRI.ArcGIS.System.dll'
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\ESRI.ArcGIS.SystemUI\10.0.0.0__8fc3cc631e44ad86\ESRI.ArcGIS.SystemUI.dll'
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\System.Core\3.5.0.0__b77a5c561934e089\System.Core.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\System.Xml.Linq\3.5.0.0__b77a5c561934e089\System.Xml.Linq.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\System.Data.DataSetExtensions\3.5.0.0__b77a5c561934e089\System.Data.DataSetExtensions.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\System.Deployment\2.0.0.0__b03f5f7f11d50a3a\System.Deployment.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
The thread 0x750 has exited with code 0 (0x0).
The thread 0x1790 has exited with code 0 (0x0).
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Users\Admin\Documents\Visual Studio 2008\Projects\MapControlApplication16\MapControlApplication16\bin\Debug\MapControlApplication16.exe', Symbols loaded.
'MapControlApplication16.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\Accessibility\2.0.0.0__b03f5f7f11d50a3a\Accessibility.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
The program '[4752] MapControlApplication16.vshost.exe: Managed' has exited with code -1073740940 (0xc0000374).
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: MapControlApplication16.vshost.exe
  Application Version: 9.0.21022.8
  Application Timestamp: 473168a0
  Fault Module Name: StackHash_d957
  Fault Module Version: 6.1.7601.17514
  Fault Module Timestamp: 4ce7b96e
  Exception Code: c0000374
  Exception Offset: 000c37b7
  OS Version: 6.1.7601.2.1.0.256.1
  Locale ID: 4105
  Additional Information 1: d957
  Additional Information 2: d957dfd33a0784e3c1277afae2788bc8
  Additional Information 3: c83b
  Additional Information 4: c83be18131e50548791f47b20e58c6e8
It seems ArcGIS Data Interoperability causes this error not VBA nor Office Shared Library.
JeremySury
Did anyone resolve this issue.  I recently updated to ArcGIS10 SP3 and when I run the default MapControlApplication and try to use the Add Data button i get the following error:
Problem signature:
  Application Name: MapControlApplication1.vshost.exe
  Fault Module Name: StackHash_662c
  Fault Module Version: 6.1.7600.16695
  Fault Module Timestamp: 4cc7ab86
  Exception Offset: 000cea27
  OS Version: 6.1.7600.2.0.0.256.48
  Locale ID: 1033
  Additional Information 1: 662c
  Additional Information 2: 662c4de66d5f651fda05e09f48208564
  Additional Information 3: 1bcb
  Additional Information 4: 1bcbe069c732b722e4d29f8893cd56a1
